Seeking Wide Bandwidth 1"Compression Driver for Home Stereo
Hello All,
I am trying to form a short list of wide bandwidth 1" compression drivers with very good sound quality that have good high frequency extension as well as the ability to play comfortably sub-1,000Hz. I would like to know the value/perfomance leaders in the sub-$400 and sub-$800 categories.
TIA.
Peerless by Tymphany DFM-2535R00-08 1" Compression Horn Driver 2/4-Bolt 8 Ohm
You're welcome.
You might be hard pressed to find a better sounding driver, even at the 10x price range you are looking in. Very elegant sounding little guy, for domestic use (probably a little small for big pro sound work).
Another nice one is the DIYSG DNA60. A little better sensitivity, smoother on some larger horns, better power handling.
You're welcome.
I think you mean the DNA-360:
Denovo Audio DNA-360 compression driver DIY Sound Group
Performance is very good, with low distortion for a CD.
The BMS 4550 has a unique ring radiator plastic diaphragm which allows a steep slope 800Hz crossover. Download the long datasheet for tech info and SPL curves. This is Tom Danley's favorite 1" CD.
Google BMS 4550 on the QSC (same as PRV W35-25-B WG waveguide).
TD15M + BMS 4550 + QSC waveguide = az's "Spendy-Wave" build | Audiokarma Home Audio Stereo Discussion Forums
I use the Faital HF108 which has a plastic dome plus a very short phase plug for smooth 1.3kHz - 18kHz in a medium size waveguide like the PRV W35-25-B WG, Dimensions: 10.1" H x 14.2" W x 5.5" D. This PRV waveguide is said to reach 1kHz with a steep slope crossover. Just $10 at Parts Express.
If you have the room and the money, look at the large JMLC-350 horns for 1kHz. Big is Beautiful.
Attached is the distortion measurement of the DFM-2535R00-08 on 18Sound XT120 horn. The measurement was taken at 0.5m distance, but with the SPL adjusted to 104dB at 1m.
You're welcome.
Have you tried the 2544R00 from Peerless? PE says it's new. Looks like a good option with a larger 1.75" vc
Comparing distortion measurements from different people using different equipment at different times is a good way to get confused.
Here is one from Bill small syns that used the Peerless, lower level again but is comparable to the other graph.
As Bill has both and has tested both he can probably give a verdict that can be relied on.
