Is this a good LM3886 Kit?
Is the noise hum? if so, it could be due to a subtlety in the lay-out of the pcb, particularly in the area of the power supply. It could also be due to the proximity of the power supply and signal circuits. That's to say, it could be either conducted or radiated noise.
One way to tell would be to feed power in from a separate board.
For general hum troubleshooting and analysis, this link might be useful:
www.updatemydynaco.com/documents/GroundingProblemsRev1p4.pdf
The screen isn't connected. You should use two separately screened wires for each channel to the PCB and you shouldn't have that additional green wire to your common ground. Use some thermal paste between the chips and heatsink
I tried the V- to the bolt and heatsink and there is nothing so its not connected. I clipped on a wire from the heatsink to the ground and done nothing as expected after the last test.
Well I'm getting lots of crackle and pop if I move the rca connectors. My only two sources of input have been from my phone and my laptop. even without any external input connections I have noise. So basically nothing connected and only power cable I have noise.
This is my first ever amp build and I'm kind of thinking it sounds like it does because I have no volume knob / potentionmeter. So at the moment I'm restricting the volume from the source like my phone or laptop and my amp is full on. I have a 50k pot here I havent tried yet maybe this will help? Also I noticed some other LM3886 builds when I googled earth rca & lm3886 and they had some sort of resistor or cap on the rca terminals. is this like using a pot? sorry for the questions.
It reminds me of a guitar amp hum.
Your thinking is basically sound. You effectively have the amp at full volume all the time, you must wire in a pot. It sounds like you also have a bad connection at the sockets. Short the inputs, that is connect the inner pin to the outer. This has the same effect as turning the volume right down to zero
Well, the idea is quite simple...If you are building a say, 4-channel amp (stereo bi amp), the eBay kits cost ~$32. If you go the neurochrome route, you're at $300 JUST FOR THE BARE BOARDS AND PLANS. Now, paying extra for a superior design is all well, and good. But an extra $260 (say the boards are $20 apiece) is HIGHWAY ROBBERY!! HALF that would be a steep price---maybe worth it.
it are boards without parts?
well my input cable is a 3.5mm to Left & Right RCA. Its cheap and nasty. Makes noise as the 3.5mm is jiggled in the phone and same with in the computer.
So if I hear you right I should now.
Use single core cable that has copper shield. Attach 1 cable to each left and right rca with copper shield to earth of rca and inner cable to signal in.
Now I have to run this wire to the new pot that is a LOG 50k stereo with 6 terminals. then run them back to the input on the amp board.
My amp board only has [L-In, GND, R-In] should I now connect both these earthed sheilds to GND?
Thanks for all the help too
Yes, that all sounds good 🙂 Are you confident how to wire the pot?
I haven't done my research yet but I have 3 of them here, all are Stereo Logs with 6 pins but they range in quality.
50k EIZZ Gold plated stepped
50K Jaycar cheapy
10k ALPS RK27
Whats the best way to connect them, I had my rca connections soldered onto the board underneath but I do have a white plastic connection on top that I can use but I dont know what they are called and where I would get them or that cable in one.
I'm really not looking forward to running the wires from the back rca to the front of the box then back to the board. I have a proper enclosure I'm building but this is all a test fit to iron out the floors like the grounding issue hums etc.
Sorry if I dont make sense its 1am here and about to fall asleep. You have been a great help.
I'd use the 10k ALPS, a nice pot. Don't worry about the wire length at the moment. This image should put you on the right track 😉
A 6pin two channel vol pot needs 8 copper wire connections.
Two for Left input.
Two for Right input.
Two for Left output.
Two for Right output.
Each pair should either be twisted or a coaxial. BOTH ends of each coaxial need to be connected.
50K Jaycar cheapy
10k ALPS RK27
Mounting the vol pot next to the input RCAs is best. But that requires a long operating rod from front to back.
If you can't do that, then you have to run long wiring to the vol pot.
Each two wire connection requires a LOW LOOP AREA at the terminations. Make an effort to achieve that.
Nover capacitors are not British.
I wonder how many other lies are in the description.
I also wonder whether any of the components are not fakes.
I do not recommend buying a kit from China.
PCBs is well manufactured can be reliable. But their layout design is often bad.
An other BS reply, China bashing, What fake components? Every component today are made in China, including 99% of the audio kits. $38 for a stereo amplifier must be a good deal. To make an amplifier with a LM3886 is not rocket science. May be care to point out the faults in the PCB design?:deerman:
Actually, mounting the pot closer to the OUTPUT connectors is better. The input signal to the pot tends to be line level (0.9-2.0 V RMS). The output from the pot is often attenuated by 40 dB or more (so 9-20 mV RMS). Thus, the output connection is the more sensitive node.
Mounting the volume pot by the rear panel and using a connecting rod to reach the volume knob is good advice, though.
Tom
