Tweeter output dead on 2-way passive crossover
The woofer side is working but the tweeter side is dead. How would I troubleshoot which part is faulty?
Here's a link to the crossovers. I see two resistors with 5W3R6J and 5W4R7J, a black capacitor, and two of those wire coils (inductors?).
Just measure the dead tweeter when disconnected from the cross over. If it's high impedance ( like 50 ohms or higher Or open circuit , it's the tweeter.
Just put any small speaker on the dead tweeters wires while the tweeter is disconnected from the crossover, if you hear some thing then it's likely the tweeter, if it's the crossover , most likely the capacitor, then check the resistors. Least likely the inductors unless they look burnt.
Unfortunately I don't but this is the link to the set I have. I do have a voltmeter with resistance reading.
Looks like a simple first order, an inductor in series with the woofer, a capacitor in series with the tweeter.
There are 3.6R and 4.7R resistors for tweeter pad. See this schematic, the resistors may be interchanged,
or maybe even connected in series instead.
First see if there is continuity between neg in and either tweeter terminal.
https://www.digikey.com/schemeit/project/crossover-TJ33DRO30150/
I'm seeing two coils on the focal link, rayma.
Something like this, I guess. Just do some resistor measurements on the low ohm scale. Shouldn't damage the tweeter.
You'd expect a crackle from the tweeter with a 1.5V battery across it too.
Check the soldering hasn't come away too.
