My M2 story
At this time ACA-2 release is dependent on DIYaudio store getting chassis,
power supply and etc together. Circuit and artwork are done.
Preliminary specs:
Three versions in a single chassis with two sinks and one supply
Class A, No feedback
7 watts stereo output into 8, 10 watts into 4 at about 1% thd
20 watts @ 8 ohms mono bridged, 20 watts @ 2 ohms mono paralleled
Nominal distortion at lower levels 0.1%
Gain = 11.3 dB
Input impedance = 50K
Damping factor = 20 @ 8 ohms
Bandwidth 10 Hz to 45 KHz
Noise = 50 uV @ 20-20KHz unweighted
same approach as F4
pretty easy and simple , when you see it explained
for more graphical explanation , see F4 manual
And surprise too 😀
Preliminary specs:
Gain = 11.3 dB
:santa3::worship::santa::cheers::xmastree::hug:
:sing::yes::xmasman:
