Acceptable Idss Range for 2SK270-BL and 2SJ74-BL
Idss of 6 mA will work on these amplifiers, sometimes with small adjustment.
8 mA is a more desirable, and is the presumed default most of the time.
Excellent- thanks so much, Nelson.
I have ordered some (Toshibas) from an online seller and requested sets close to 8mA Idss (he tests at 9.00 V).
Seems a legit supplier - it is a (pro) audio manufacturer who bought the JFETs from "top-line U.S. distributors". Fingers crossed.
John
Who did you get them from? The only dependable source with idss all through the sweet area I know of is Spencer. Always genuine.
Russellc
The seller is Millennia Music & Media Systems.
I got them here (hoping they were a smart buy). I note that the upper end of the Idss range is lower than when I bought. I requested mine were as close as possible to 8 mA. He as pairs as wellas quads, as well as some other FETs.
"FETs are matched in pairs to within 0.03mA Idss AND 4mV Vgs."
Toshiba 2SJ74 + 2SK170 MATCHED QUAD to 0.03mA AND 4mV 7.2mA-7.4mA Idss Range
While they might be genuine, it's hard to believe they're new. Those legs look resistance-welded on, don't they?
(As does every other seller's on eBay; and they all describe them as "new, unused". Am I missing something, or is truth truly out of style?)
I have bought from the guy in the past but I cannot remember if they were genuine or not. During that time, before the LSJ74 was available, I tried a few of the Ebay sellers. Most were fakes. Buyer beware on Ebay. It is always best to have matched sets but not a deal breaker if they are not. You will have more 2nd or more 3rd with a mismatched pair but it can be corrected with some source resistance if you do not like the sound. Sometime people like the sound with a mismatched pair better depending on whether you like more or less 2nd harmonic.
My vote is for LSK only for the J-fets.
I know John La Grou personally, I remember when he bought them, and you
can bet he matches them that tightly.
Read above post - I feel good about my analysis and decision.
Yes, it sounds as you have found a good source. These sources are rare as hens teeth. I have, and I suggest you as well, lay in a small supply to use in the amps you plan to build.
Its nice the store provides the linear versions, but I have previously inquired if idss can be requested, but never got a response. I have a couple sets of them, but have no idea where they measure idss wise.
Havent had a need to find out by measuring them, I just ordered sets measured by Spencer.
Happy amp building!
Russellc
Extremely tight matching. Sounds like you chose good units.
Russellc
