LM1875 Need help
Hi everyone! I have always been interested in audio designs and always wanted to design an amp from the IC up. I finally did it and I bought 2x LM1875 chips.
The problem I am having is that at higher volumes is really distorting especially for bass and to some degree just treble.
I am using this schematic from the Manuel itself (Figure 2.) since I don't have a split supply. Another issue I am noticing is that at higher VCC voltages it cuts out? I am not sure if the gain is too much or anything.
I am really new to this and I am very interested in learning and improving my skills on DIY audio systems.
Congratulations on getting this far on the first try, many don't.
The schematic seems ok, can you post photos of your pcb?
Are you sure that all the polarized capacitors are connected the right way?
Also, are you using a heat sink on the LM1875?
Quoted from the same data sheet you got the schematic from :
POWER DISSIPATION AND HEAT SINKING
The LM1875 must always be operated with a heat sink, even when it is not required to drive a load. The
maximum idling current of the device is 100 mA, so that on a 60V power supply an unloaded LM1875 must
dissipate 6W of power. The 54°C/W junction-to-ambient thermal resistance of a TO-220 package would cause
the die temperature to rise 324°C above ambient, so the thermal protection circuitry will shut the amplifier down if
operation without a heat sink is attempted.
Just makes me keep going. I am really intrigue by all this.
Here is the picture boss LM1875 setyp - Album on Imgur
Solderless breadboards are appealing, but they must be used with great discretion.
Try much shorter solid interconnecting wires. Place the bypass capacitor C7 close
to the device pin. All the grounds should connect very near each other and the device.
Does the device run cooler now, or is it still hot, and maybe oscillating? Do you have a DVM?
Never work when you're rushed, tired, or upset. Bad things will happen.
Shorter wires got it.
Grounds closer got it. (The ground is PIN 3 right? really confused on this concept here.)
Bypass capacitor already next to chip (Pin 5).
I do have a DVM want me to check something?
The device runs cool now and its not oscillating the gain is greater than > 10
