Hi apex
is this step driver are in working ? and can handle possible voltage around +140-+70-0 dc,SD-5
thank you.
Hi.. this Step driver should work OK since it is the same circuit used by Crest Audio in one of its model. I will use this circuit for turning several AB amplifiers into Class H.
