Port length
So i've got a boombox enclosure with 10 litres. Drivers are dual 4" Faital Pro 4FE32 full spectrum. With the online calculator I used a 30mm inside diameter single pvc hose with 8cm length. The sound is totally miserable.
I removed the port and filled the hole with the before cut piece and sanded it.
Now i got myself a 36mm inside diam. port. I'll use dual ports on each half sides of the back panel. Since I can't trust online calculators no more I'm leaning towards your help guys. What length should i use? Tuning should be around 81Hz.
If i understood correctly - you will be using 2 pieces of 4fe32 in 10 liter volume and you are planning to use 2 BR pipes per cabinet with inner diameter of 3.6 cm ?
If that's so, the length of pipes should be 7.5cm each for tuning at 81Hz. It looks like this:
I used these two online calculators.
LinearTeam
Port Length Calculator
I use macintosh but have access to windows pc occasionally. These calculations are very unfamiliar to me, so many parameters I don't know how to properly use therefore I'm a bit sceptical using the simulating software.
Longer port means lower tuning? I'm limited with enclosures depth with around 11cm for the ports length. So leaving a few centimetres after the inside port opening might be advisable?
Thanks everyone for your replies, N
You're welcome!
This calculator specs a bit too long a vent, so tunes it a little lower, though wouldn't normally be audible. Since it doesn't do multiple vents, there's no frictional losses accounted for, so may be audibly lower if tuned > ~40 Hz. Again, not normally an issue unless trying to tune to exact Fs for whatever reason.
A pipe's basic end correction is radius*0.613, so 3x this length is a good plan, but folks tend to just use the vent's diameter.
GM
