Joined 2009
I can't imagine such a crowded beach....excepting the sharks
The solutions is simple....
@ your birthday party -
First human being is in fact not a human being at all
but rather a wax representation of of human being.
not too hard on the eyes,
however,
that was last year.
now looks like -
I have a 92 Honda Civic. I cleaned out a switch and put new contact grease in, but then I accidentally broke the pivot that couples the rotary knob to the linear switch. It's a thin 2mm stem with a ball on the end. I tried superglue first, it worked for a few months. I just put JB Weld on. What kind of plastic do you think automotive switches are made of? JB Weld apparently doesn't stick to PP or PE well, but if I made a mistake hopefully it will break clean.
Some big claims for these modern UV curing glues - 5-Second-Fix-UV-Light-Liquid-Welding-Kit-Welding-Compound-Glue-Repair-Tool
Dan.
Dan.
We use that in the lab when securing thermocouples.
It works a lot better than the Loctite 401 and otehr Cyanoacrylate glue we've used in the past.
https://www.instagram.com/angela_nikolau/
I like this picture
One leg goes one way
The other leg goes the other way
And the guy in the middle is like: "what do you want from me?"
- Member Areas
- The Lounge
- Threadjacking
