Threadjacking
Actually I think I made a mistake. The thermal conductivity of Mylar at 300K is 0.0008W/cmK. So for a TO-247 which has optimistically 5cm^2 of surface area, and a film thickness of 0.5mil (why make it thicker than needed?),
1/(0.0008*5/.00127)=0.3175C/W
That is assuming the metallization is not on the transistor side.
For them to work well though the transistor and the heatsink has to be flatter than 0.0005" across it's surface to achieve flush contact with the film without crushed spots with reduced breakdown voltage. So maybe not really practical, especially not without grease.
Pardon the near-on-topic post, but I just saw this "Coaxial Speaker!"
wonder how much, a few hundred would cost ...
some women are more exciting than others -
Couple Climbs The HIGHEST CONSTRUCTION SITE IN THE WORLD 640M - YouTube
https://youtu.be/tlEyZDPaqiw
- - - Updated - - -
I have an old Makita power drill. The cooling fan broke and the variable speed is stuck at high. I took the controller apart and the sliding resistive element is missing. I don't know if it's possible to replace it with something or what resistance it would need to be but I believe I found the applicable patent:
https://patentimages.storage.googleapis.com/pages/US3327196-2.png
Makita 6406 3/8" Variable Speed Reversible Drill Parts | Tool Parts Direct
Maybe I could cut up a linear potentiometer?
The capacitor is 47nF and the SCR is marked 35-275.
Fun at work....Ready for final sanding and finish.
Having a very good handsaw and understanding how to use it matters greatly. Some practice doesn't hurt either.
A lot of cutting that isn't very nice comes from a lack of knowledge on how to use the handsaw. I've seen amazing work with what people consider crude saws (large), that are sharp.
