F5 power amplifier
Infact this channel is working well while using the current limiter jig, and bias set's too around 0.56V with 0 DC offset, but as soon as I remove the current limiter, it never stabilise
You can not set the bias of F5 properly with current limiting contraption like "bulb tester" (it's useful for class B amps but not in case of F5).
First take some time to read this (especially pages 6-18) and understand how this amp works and how to set it up correctly :
http://www.firstwatt.com/pdf/prod_f5_man.pdf
Sure Juma, I understand, but F5 was drawing too much current and would blow the resistors, transistors and fuses, the limiter had to be included...well on a sample basis it solved some part of it and I could hear Music...so its more a confidence building thing...will go through the link and retry...thank you for the support
Sent from my iPhone using Tapatalk Pro
home made f5 🙂
Sounds fantastic on test psu 2x20V, mosfets from ebay. Worked like a charm from the first powerup, no nasty surprises. With 2x100r resistors gain is too low for my sound card, so I guess I'm going to experiment with some higher values there.
Thx guys, I'm learning a lot on this forum and implementing that as I go. I'm listening Armin Van Buuren right now on F5 and testing it. Heat sinks will be adequate in the final version, depending on the casing of course. 🙂
For R21 and R22 is there a consensus as to whether 10K or 22K1 resistors work better? I just soldered the 10K resistors in, and then found the extra set of 22K1 resistors from the kit unused. So, am kicking myself a bit for not knowing this before soldering, but is it really worth replacing the 10K resistors? I have only started one channel, so I am also thinking about building the second channel with the 22K1 to see if there really is a difference (to me). Thoughts? Thanks, Andy
