Denafrips discrete R2R Multibit
Both Soekris and Denafrips (afaik) are Sign Magnitude DAC's, they don't need that precise resistors as a non Sign Magnitude DAC's, like the TotalDAC.
For people that still don't understand the very significant difference, please read up on it. Short differences:
Non Sign Magnitude: Distortion is relative to full signal level, so increases with low levels.
Sign Magnitude: Distortion is relative to actual signal level, so stays low at low levels.
And 0.005% initial precision resistor is kinda irrelevant as Denafrips (according to their website) use 10 ppm/C temp coefficient parts anyway, it's more for marketing....
Wkkkkkk someday Eldam. We both know that it takes more then
a dac chip to achieve great sound right. Diyed 2 dac's before but
results not a great as I thought, so better leave it to Guru's like Pedja
to do the dirty work & me just tweak the dac to my liking. LOL
Me I don't care, I'm sourcing parachut curses to land in your island garden with my DAC one day! You will hear yourself ! Just need some bigger foam pad for my AYA box lol !
Of course if I was rich I will drop with a complete philarmonic grup of musicians... but more expensive and need more Nasi Goreng than one guest, lol !
Another difference in the resistor network is Soekris use LVC shift ic with 4V and Ares uses VHC with 6.9V. I wonder if that gives a difference in sound.
The LVC types have lower output impedance and are faster, while the VHC can tolerate a little higher voltage, although 6.9V is pretty close to their absolute maximum.... Can't see that by itself it should affect the sound much....
Do you know the resistors values on the Ares ? Probably higher than mine.....
It's all a question about compromises, higher R-2R network resistance means more tolerance to driver impedance, but also higher noise and higher switching feedthough.
How about adding a mosfet after the LVC logic? Like FDS8958...
So what is the function of the large capacitor bank? Is it for vref?
I did a quick check of the inside earlier, some of the rolls of cap bank are for each of the five lt1763 (1.8v, 3.3V, 5V) post decoupling. I think there is one rolls for pre decoupling into those lt1763. And one roll for pre regulator of the resistor network.
Note image is from Ares homepage. If you check the lt1763 from datasheet, you can almost tell where Vout goes to.
