SB acoustics 8" / HiVi RT2C Build thread!!!!!
So there was a HiVi emblem on them? Or was it hand-written?
FWIW, they will fit the same recess in a cabinet, and have a lot of similar parts, but the PT2-C is not made by HiVi.
This means packaging is interchangeable.
Later,
Wolf
I had them open to examine the membranes and HiVi is written on the pcb-like frame that holds the membrane.....
They also came in HiVi packaging. But none of that matters... they are in the trash now🙄
I am now waiting on the Peerless ring radiators before I start cutting wood.
Hi Mctavish,
Did you finish your bookshelf project? I’m quite interested in same bass drivers and would make something similar, if you give me positive feedback! I have 25l netto volume in a BR configuration, and would cross them around 2k with thh Monacor dt 25...
Thanks in advance
