Threshold 4000 rebuilt - buzzing, need advice
I have rebuilt a Threshold 4000. Everything has been changed on the front end and output boards. Basically, all that is original is the transformer, bridge switch, wiring and the meter board. Bias has been set. Reproduces music fine (good numbers when tested with HP 8903)
I'm getting a buzz (60 hz) which gets worse as I wiggle or move around the ground wires in the amp. It's the left channel but right will have some buzz too unless I remove the fuses from the left channel.
-I've checked all of the components on the left FEB, except resistors.
-Compared a working 4000 with the same circuitry design to make sure I didn't install something incorrectly.
-Tested with RCA shorting plugs, buzz gets better but still there.
Thinking it has something to do with a ground or a ground loop. I've checked all the grounds, resoldered ground connections, checked to make sure all grounds match those on the working amp. All looks good.
I'm about to start switching boards with the working amp to see if I can isolate the issue, but, before I have 2 amps in pieces, I thought I'd ask for some help!
Anyone have any ideas??
Thanks,
Eric M.
Can you expand on this bit?......a bit 😉
Is it totally silent if you remove fuses from just the left channel?
I have more, let me know if you need a close up of a particular area.
Yes, let me add some detail:
-If the fuses are out of the left channel, the right does not buzz, it works fine.
-If fuses are in the left, both channel buzz but the left is louder. (it's loud, like "I screwed up somewhere loud")
-The buzz sounds like 60 cycle hum (from what I recall from my Junior High electronics class) but measures 120 Hz with the 8903.
-If I wiggle the ground wires (especially the 2 that go to the left front end board) the buzz will bet louder of quieter. I can actually "strum" them like a guitar string and the buzzing will sound like a bass being played (does that make any sense?)
Thanks,
Eric
These wires (not sure why there are 2?, I can't find a schematic), the screen of the input wire and the black wire from the RCA skt to the star are forming a loop.
I've also wondered why there are 2 ground wires going to the FEB board, but it's that way on all my 4000's and 400a's. I know if I remove the ground on the shielded (screened) cable, the buzz is even louder. I can try removing the 2 ground wires to the FEB but am concerned they are there for a reason and not a mistake.
