Gpapag, the TEK 475 is a pretty good scope, so long as you don't spend (forever) in fixing it. I use a TEK 485 on my bench, and love it. I had to repair it once, however. It lost its computer grade power supply cap! Still, I can hardly do without it. Bandwidth above 60MHz is important. Oscillations can happen in the 100's of MHz. Trust me, I have seen them.
Sync, what is the filter you are concerned with? Just give me a simple answer. In general, simple filters are easy, exotic filters are almost impossible. Back in 1974 I got a book, 'The Active Filter Cookbook' and it solved 90% of my problems then, and would today. However, for an exotic anti-alias filter, I hired my first PhD in 1974 to do it for me. Same would be true today. So again, what do you need? (in simple terms)
Thanks for the pics George. I see the TEK. Not bad.
Oh then the WTF?
You mean that little thing on the desk?
Residing by the 9V battery?
The one with the (dating myself here too) wind up stop watch thing
on the top of it? So that isn't so bad? Even for a wind up hand held
mini scope. That is pretty neat.
I bet most of the people in this thread have lab equipment far exceeding the value or their stereo.
Some stuff is affordable, but then again not... matter of perspective. Even though a 200mhz scope back in the day was hot ****, realizing today that a 500mhz would be best for your use and looking at the price will bring you right back to earth.
Don Lancaster's book: 'Active Filter Cookbook' is available from Amazon Books. It is about $35, but you might find one used somewhere. I highly recommend it to you.
For those looking for something easy to work with to get started, here are some resources at TI:
FILTERPRO WEBENCH Active Filter Designer | TI.com
https://focus.ti.com/lit/ml/sloa088/sloa088.pdf
http://www.ti.com/lit/an/sloa093/sloa093.pdf
Haven't tried it myself, but the designer app might be okay.
In any case, filter design is a big subject. Getting started can be pretty easy though, at least compared to long ago when some of us around here started learning about it.
600W type R bovine pure linear computer power / have a fever PC power supply.
Bovine and fever are mistranslations I have read on other pages.
Anybody know the correct translation ?.
Dan.
The high life of audio and video cables
Abstract Translated from Chinese
The utility model relates to audio and video cable technologies, especially the kind of life a high audio and video cables, including the transmission line and connected to the transmission line at both ends of the connector, the connector includes a housing, metal housing and disposed within the housing two rows of terminals, cover the terminal is connected to the outer layer, the outer cover and the other end fixedly connected to the housing, the end of the housing is located within the housing, and the other end extending out of the housing, the housing ladder at right angles, is located outside the housing on the housing the outer end portion sets a sealing gasket, the gasket is fixed to the ends of the housing, the utility model of the high life of its audio and video cable connector when inserted into the terminal end face of the housing against the gasket the outer end face of the gasket and the inner end surface of the terminal fitting, the sealing gasket from the seal between the cover and the terminal connector, effectively avoid the outside moist air from entering between the cover and the terminal within the terminal terminals and housing sockets and connectors on the cause corrosion.
Dan.
@ Everyman,
Thank you for your suggesting. I bought all of them plus a few more used for about
$20. USD. They should arrive in a week or two, depending on location etc.
I just hope none mold/mildewed out as those go to the trash. They were all
labeled as used from good to better. Not a collector so good used is
okay with me. They will be put to good use.
@George, LOL I see the BNC now. Looking only at the small pic
it looks like a windup watch.
@John, got it and picked up some of Lancasters other cookbooks too.
@Ed, got it, looks to be good used prices for these.
Okay, back to working on part of the filter.
This should be pretty straight forward,
even with a JFET amplifier.
I've got something not right.... It should just work.
May all your designs work correctly the first time.
Thanks Ed, THAT is the book I used way back then.
Sync, you will find vital practical info in Lancaster's books. He wrote for the rest of us, practical designers, not just the academics. Of course, they are quick and dirty solutions, and other more complex textbooks can sometimes be useful, but usually there is too much complexity, math, etc, when what you want is a simple direct solution.
