TA8210 dual mono amp
Hi everyone.
I want to build dual mono(2 ta8210 chip For 2 Channel) amp.
Can anyone give me simple instructions wrt casual single bridged ta8210 amp diagrams on The google?I couldn't manage attaching Photo this post..
My main goal building dual mono classAB 12Vdc amplifier..
Thanks..
reed the datasheet TOSHIBA - datasheet pdf this amplifier is already bridged. You have only to mount this amplifier.
Hi.May I ask a question?
I looked a lot of schamatic For ta8210 stereo.
I think I can use 2chip For 2 Channel.
I COULDN'T SOLVE ONLY ONE THING:
pin1 is mute pin.
Pin4 is standBy pin.
Some diagrams Connect one of THESE PINS to 1led-1 zener diode-1resistor BATTERY STATUS INDICATOR.AND other pin weren't connected to anything.
What happens if I don't use pin1 and pin4?
Why did they Connect The battery-status-indicator To pin1 or pin4?
And how can I Connect The battery status indicator while using 2 ta8210 chip?
Thanks..
I think pin4(standby) default mode is OFF.
I tried to do some calculations.
Can Someone confirm these calculations are Right?
