SMPS Power inductors & Flux fringing
Disabled Account
Joined 2014
I
Ahh yes margin tape would work much better than tube, unfortunately I don't have any as I have moved over to using TIW (Triple Insulated Wire) for all my high voltage transformers. Yup getting hold of gapped cores is very difficult and expensive BUT the gaps are precision compared with DIY solutions, also gapping the outer legs increases EMI considerably and that is probably my worst enemy. Always useful to know what the professional solutions are 🙂
Indeed, and it makes the gap much more undetermined, due to the enormous amount of fringe field.
Be aware that your solution, although certainly effective, does have some perhaps unexpected side-effects: the turns in the vicinity of the gap help to contain the fringe field; of course, they cannot contain it completely, which is why your solution is effective, but moving them farther away also move the fringe's reach.
In an ideal situation, all the ampere-turns would be concentrated in a single sheet tightly wrapping the center leg, and all the fringe fields would disappear.
In practice, this is not possible, and some trade offs have be found, but it is good to keep in mind the underlying problems
