I have a question for everybody that I can't completely understand:
I am watching the first F1 race in Melbourne, Australia and I am amazed how wide the tires are this season. What is the advantage? As I remember from an early physics course, the size of the tire patch should not make any difference with typical materials, such as wood, etc. Why do racing tires work differently?
If memory serves, the short answer is that the width is required to distribute and dissipate heat.
Another factor is that race compound tires wear very quickly, and there is a limit to how thick the rubber can be made due to squirm of the rubber under cornering loads. In fact if races are short, sometimes the tires are shaved down to reduce rubber thickness and improve performance. By making a tire wider, rubber wear is distributed across the width of the tire, so the rubber can be kept reasonably thin.
Tires, especially width, are a core part of the formula. Namely, in open wheel racing they're gigantic aerodynamic bricks that keep top speeds a little slower, but aid in low speed corners. There's also plenty of nonlinearity in tire pressure/contact patch shape and coefficient of friction vs. load. Oh, and wear, which, all else equal, a wider tire will win (on simply having more rubber around to work with).
Back when I did Formula SAE (seriously cool stuff to work on), we did a lot of kinematics analysis on suspension and tire loading. In our case, wider wasn't necessarily better, but F1 demands are a *little* bit different. 🙂
John, how tyres work and affect driving you can easily evaluate for yourself by simply changing them by general type and dimensions. You don't need F1, just remember that due to driving conditions what you get in personal evaluation you'll get on F1 as well, but more pronounced.
Last summer, I was a little surprised when my wife said thatg the current (summer) tyres I use (from Michelin, standard 205 R 17, were audibly more silent than the ones before (Cooper Avon), my wife whose concerns regarding cars boil down to having an air con and a decent music system. Michelin is usually hell bent on low road noise and energy efficiency (low rolling resistence), and make good on most of their claims in those regards. To that, I would add also excellent road holding on wet surfaces, better than most, one of class leaders, but by no means unique (in this respect, Continental and some Goodyear models hold their own as well).
Race tires, like F1 tires, have little thread in a struggle to use as much surface as possible and pay little attention to road rolling noise. But grip is improved, side walls are as little angled as they can be and are reinforced for really naughty speeds compared to normal tyres.
Thus, there is no simple answer to which tyres are best, since they are adjusted by design for the type of driving reqired under given conditions. F1 is one set of conditions, but rally is quite another as you are expected to wallow in mud no end.
For regular driving you and I are most likely to do, my personal choice would be Michelin tyres, but not 215 R 17 as recommended by GM for my Chey Cruze, ather the ones I have now, 205 R 17, which reduces the width for the benefit of improving traction under adverse conditions, such as wet roads. But then, that's just my opinion, a more aggressive driver will probably go for 215 R 17, and even 225 R 17 for tackling sharp curves.
Here is an interesting discussion of just this issue... Refers to "THE RACING & HIGH-PERFORMANCE TIRE" which I can't say I've read, but sounds like a great resource!
See also:
Pelican Technical Article: Physics of Racing Series
John, did you know that a set of four tyres (two front and two back) for the Bugatti Weyron cost, as a set, €20,000 or app US$ 21,000? Wanna drift at those prices?
Too much? For a vehicle costing over $1.5 million? With a quad turbo V16 engine?
Well, it's hard to say. That tin can has been proved to be capable of speeds in excess of 400 km/h or app.250 mph. At such speeds, tyres will in any case become quite warm, yet they still must keep the car on the right track in a fully controlled drive condition. A blowout at such speeds is completely unforgiving.
A bit like aeroplane tyres. They are not much to look at, but they have to carry like 250 tons of airplane at take off or landing speeds of some 160 knots and accelerate from standstill to full speed when landing. Who's going to argue the prices?
That has pretty much been my experience as well for the past 70 years. So, I tend to believe the differences are real if a large number people are also describing in same way as I would.
Funny that the BS here follows the idiots writing the reviews like the one John posted often too closely. If you actually research what "this large number of people" hear it's' "I hate you, but I love you". Case in point google op-amp rolling and spend a few hours.
Even JC follows it! 😉
@JC earlier, when asked about this ad you posted, you said you are a physicist but couldn´t follow the JB stuff. But when I, as a non/physicist read that C13 ´goes to a higher energy level´ or something like that, I immediately thought ´where does that extra energy come from´. Why don´t you as a physicist ask yourself such questions??
Jan
Grip, it would be illogical if footprint size wouldn't mater.
Nothing new, energy out of passive devices is a common thread in JB's claims. This stuff is no more credible than the spoon benders or other sleight of hand.
Scott, Scott, Scott,
So nice to see you and the others all behave exactly as predicted when your chain gets jerked!
"News" sources that are nonsense except to their true believers, wonder where that would go?
Doing a presentation next week where the properties of sound propigation in air at the specific site is an important consideration. Yes it is a smidgen bigger scale than your listening room, but at what scale does the issue go away.
But one could try an interesting experiment. Does placing an ionizing smoke detector in a familiar listening space make a perceived change?
Humidity, non-uniform temperature, gradients due to HVAC all matter in huge venues, I already posted Dave Greisinger's measurements. Action at a distance with no source of energy does not fall into consideration, it's all made up nonsense, Star Trek physics (Quantum Slipstream Drive).
The radiation dose to the occupants of a house from a domestic smoke detector is essentially zero, and in any case very much less than that from natural background radiation. The alpha particles are absorbed within the detector, while most of the gamma rays escape harmlessly. The small amount of radioactive material that is used in these detectors is not a health hazard and individual units can be disposed of in normal household waste.
EDIT - Ed the real problem is that we continue to respond rather than just ignore it.
If that is not working for you (general speaking not pointing at any one in particular) then we could start a thread about the next possible improvement and why it failed.
Amplifier Institute Failures (look at project #8)
Wonderful, the ultimate anechoic environment. We once had a long thread on micbuilders about reducing noise on a condenser mic by evacuating the back chamber. 🙄
