Has anyone ever come across resistors that you would swear are film caps? Have a look, and YES it is in fact a resistor.
Now begs the question, what type of material. Any info or educated guesses someone may be able to provide is always appreciated!
I'd be checking it with an ohmmeter, just to be certain. Must be a special purpose design, or perhaps it is a RC snubber.
Agree, check with ohm meter. A snubber or other similar little network is a good guess.
Plenty of guys are fooled the other direction, the little ceramic caps that look just like 1/4w resistors.
It's not my first rodeo 🙂
As I said, it is in fact a resistor. It's hard to make out in the pic but it even says 100Ω on it.
http://www.nikkohm.com/nikkohm_e_pdf/rp84rp44rp24rp14eb_e20160501.pdf
Interesting resistors for audio circuits
My pleasure Bigred
This is not the only one brand who make resistors in this " caps" style
some Vishay or Susumu are made as well :
http://www.susumu.co.jp/common/pdf/n_catalog_partition28_en.pdf?v=3
They look just like what the doctor ordered for a project I am working on, now to see if I can find a source. Surprising what you find here reading random threads. 😀
You can find them on the flea market
10PCs susumu RE-55 10K 1% 0.5W METAL FILM RESISTORS Audion 1/2W AMP DAC | eBay
2PCs Nikkohm RP-44 3.3K 0.1% 0.25W METAL FILM RESISTORS Audion 1/4W AMP DAC 3k3 | eBay
thin film, non - inductive , non- magnetic have in theory
better noise specyfications if compare with thick technology resistors.
The very low temperature coefficient and 0,01 % tolerance cost much more no doubt.
Greetings 🙂
Greetings 🙂
I'll have a look on eBay, and look for a local vendor. The application is not very price sensitive.
Economic alternative if compare with Caddock or Z-foil TCC or Vishay resistors.
Ok they are different that interesting
- Design & Build
- Parts
- Resistors in Metal Film Capacitor Clothing
