Pics of my DoZ amplifier
Disabled Account
Joined 2001
Hello.
Here are some pics of my DOZ amplifier.
This is one of my first project. it is around one year old.
The total cost for amp was 130$.
janey
Looks very good indeed.
BTW, which PCB did you use ?
The smaller heatsinks are the capacitor multiplier psu, aren't they ?
Please add some infos with the images.
How do like the sound?
Klaus
ps: I am always "a bit" jealous when I see friends making their first DIY amp and the dammed thing looks so fine, like yours - I made lots of amps in different states and sizes in the last 30-something years and not a single one looks close in any way...
thanks all for coments.
i made PCB boards my own ( not realy big problem)
yes a use capacitor multiplier psu beacouse sounds better in this amp.
but this is a realy low cost project so the capacitators and resistors are not exotic thinks.
some day i will change output transistors with mj15003.
the sound is quite good exept power. but for normal listning is good. in sound quality bits rotel rb981 amp. better space, trebble..
Hi Janey,
What transistors are you using for the capacitance multiplier? I see one T0-3 transistor, are you using a pair? I'm curious as to how many you have and what kind of heatsinking you're using for the multiplier.
Hello
You can share PCB file DoZ. Thank you.
