I'm building a passive summing box, and I need some advice, because i have little experience in dealing with electronics.
It is a stereo bus, and I have connected all the inputs and outputs together with a pin 1 (ground).
My question is, can I ground the wire, connecting all the pins together, to the chassis...? What would be the best way to ground them and reduce noise?
Thank you very much, and excuse my noob-ness 🙂
I hope there's some resistors somewhere.
Get an alligator clip lead. Try with and without your chassis connection. There's FAR too many unknowns in your post to hazard a guess. Even my own work, try-and-see is often my best path. Especially with a "simple" thing like one bond wire.
Of course it has resistors 🙂 only I have not started putting them yet..
The design is based on new york dave's schematic.. I guess you've heard of it.
http://www.twin-x.com/groupdiy/albums/userpics/balancedmixnetwork.pdf
Of course it has resistors 🙂 My workflow was to connect all the grounds, and then do the rest.
The design is based on New York Dave's schematics.. I'm sure you've heard of it
Only without the mute buttons and assign switches...
Thanks, for the advice, I'll try it out.
Hi, i'm building an 8ch passive summing buss based on the design of New York Dave.
My question is concerning the mute switch... In the original design a DPDT switch is put, but I can't figure out why. In my own diagram, I put DPST - NO switch connected to both Tip and Ring pins. Can you tell if DPST will work properly the way i drew it and if my schematics make sense?
Here is my schematics:
Though I was seeing double double.
The mute will mute; but the mix-loss changes with number of inputs disconnected.
You would usually short or near-short unused inputs to preserve loss.
Is that why New York Dave used DPDT switches in his schematics? To short the inputs..? Or he just ignored that "rule"
- Live Sound
- Instruments and Amps
- New York Dave's Passive Summing Mixer - Mute Switch
