High gain amplifier trouble with positive feedback
I am building a single channel dual mode amplifier (CLEAN/HIGH GAIN).
This circuit is a draft, which I need to finish of course.
My problem is that when I increase the DIRTY POT, after 3 I get a 4kHz noise. So, there is a positive feedback somewhere in the circuit that is making me crazy.
I literally unplug the whole TREBLE POT from the circuit, and when I feed the amplifier with a signal, I can see from the scope that the signal is there.
I grounded the back of the POTs to GROUND SIGNAL but this is not helping
Any idea about how to solve this?
Thanks a lot
Quick and dirty fix is replace 12ax7 with 12au7.
I designed a USB valve mixer and it was terribly noisy with the 12ax7.
Then worked out I had a gain of 10,000 !!!!
Popped in a couple of 12au7's and the circuit settled down and worked well.
Valves are very touchy about layout.
1/ Keep transformers away from audio signal.
2/ Keep high volts ac away from audio signal.
3/ Keep input wires/tracks of amp as short as possible.
4/ Use grid stoppers and place them right up to grid pin.
