I´m sorry to say that my amp played fine on 1 channel,when I connected the other speaker the amp startde to oschillate and started to smell bad and now theres a constant current draw of 5 ampere....and it gets hooooot.well thats the end of that.
Some of the 41Hz website content is available here as well:
https://web.archive.org/web/20111031111101/http://www.41hz.com/forums/content.php?239
Sadly there is no archive of the forums.
When I backed up the site with the Firefox scrapbook plugin, it only went to a depth of 3 links and much of the forum content was 4 links from the sitemap page I started on.
So I have a list of postings, but no content for many of the different sub-forums:
41Hz Audio Amps Threads / Posts Last Post
Small amps based on TA2020 and TA2021B, up to 2x25W
AMP3, AMP32, AMP32-PS, AMP6, AMP6-BASIC. Small amps which typically run on a single 12V supply.
Medium power ampes based on TA2022, typically 2x50W
AMP1, AMP5, AMP10. AMplifiers based on the +/-30V TA2022 chip. These are typically 2x50W-2x100W or 200W bridged
High power amps based on TA3020
AMP7, Truepath, AMP15. Amps for up to +/-60V supply
TC2001 chipset amplifiers of all sizes
AMP2, AMP4, AMP8, AMP11 and TDC2500module based amplifiers. All are built with surface mount components.
Four channel TAA4100A based amps
AMP9, AMP9-BASIC based on the 4 channel TAA4100A chip running on a single 12V to 28V supply.
Typically used for mobile / car / bus / boat applications
Power Supplies
About all types of power supplies
Misc 41Hz Audio stuff
If it did not find a place elsewhere, it goes here
Other audio related goodies, tools and resources Threads / Posts Last Post
Building and testing electronics
About building, soldering, testing, measuring amps, audio and electronics stuff
About class D / class T amps
About switch mode amplifiers
Other Audio Stuff
Misc audio stuff. Loudspeakers.
I seem to post this question about once a year, not sure if I've asked anyone on this list...
Does anyone have Assembly Instructions for the AMP10 (regular Amp10, not the Basic version)?
Maybe Havoc or Scratchy?
I emailed V-Bro a few years ago and he said he had all AI for all 41hz amps but I wasn't ever able to get them from him.
You could try to call the site owner or write him a letter.
http://www.whois.com and look for 41hz.com and search further at www.ratsit.se Mobile phone numbers in Sweden starts with +46070....
Here you go - build away!
https://drive.google.com/open?id=0BxUZKhzrYS3iYWNiSU1FQ0pxX0U
Awesome! Thank you so much!
I'd pretty much given up on ever finishing the amp. Now it's just up to me to solder it up correctly 🙂
Does anyone know the watts into 8 ohms for Amp 4?
Amp4 is 24-36V, so according to P=V^2/R
And the rule of thumb that you take a third off for overheads, another third because you don't want t listen to 10% distortion, and you're left between 20-50w depending on powers supply.
Thank you! Very helpful.
Hello,
i am looking design layout/instructions of AMP2 from 41hz.com to build one.
Does anybody have it and can share with me?
Very appreciate.
Very appreciate.
You are in luck I think, I have, what I got with the kit.Hello,
Very appreciate.
-=[ classD audio :: Home Page ]=-
End of the page is link to PDF
AMP2
Hello Scratchy, I found my kit of the Amp 2 and am having a go at putting it together. Matching the parts to the BOM from the AI is more than a bit difficult - do you have the complete spreadsheet as per your posted photo?1st photo is the spreadsheet I made with parts placement & optimization calculator.
Here you go:
AMP2 - Google Drive
The spreadsheet has multiple tabs. One for calculating resistors based on input values.
Another tab has a spot to tape the SMT tape to each row, with locations for each component. Just print the sheet and stick the SMT tape to each row.
I've also included all the datasheets I could find for this amp.
AMP2 - Google Drive
Thanks very much! My AI is not nearly as comprehensive as yours. Am looking forward to putting all together after quite a few years in "storage".
The amp32 is fully replaced by a DIYaudio vendor
http://www.diyaudio.com/forums/vendors-bazaar/265881-some-more-really-small-amps.html
Same size, better output power (up to 2x42W), lower idle power, and as good if not better SQ.
The TPA3132 chip it is based on is an automotive qualified package shrunk version of the TPA3118.
Put this into a box a while ago. Very efficient but lacks the depth of the Amp 32
Does anyone have instructions and schematics for the original AMP9? I built it some years ago and shelved it. Lost all documentation and instructions for it. I would appreciate it very much is anyone can share anything on it. I have figured out the basics to get it operational but there are some extras that I want to know what they are for. It seems like they are not used? Particularly U3, U4 and U5.
Thanks in advance.
Thanks in advance.
Does anybody have the assembly instructions for the AMP10 Basic? I have one but it shorted and I'm trying to sort it out. I have most of the info, but really need the layout showing component names and locations.
Thanks in advance.
Take care,
Peter
Thanks in advance.
Take care,
Peter
Looking for PSU1-VR kit assembly instructions
Hi, I found an old PSU1-VR kit from 41hz but no instructions. There are a number of very small smd components that I am not sure where to place. Desperate for the assembly or even schematics. Help??
- Class D
- 41Hz forum dump
