Tas5630+smps+aluminum case finished!new year coming!
Hi Ed,
I bought the G6H Beta version directly in China and as far as I remember I paid around 1500RMB, but it is a Beta version and looks hand soldered. As I described earlier it is working very well and the sound quality is comparable to the TI evaluation board. I use a Mean Well RSP-1000-48 as a PSU for the TI board with disconnected fans.
Brgds. Manfred
Hi Ed,
Brgds. Manfred
We admire the meticulous engineers like you, this is the Chinese Government has strongly advocated the spirit of craftsman, we will continue to work hard, and strive to make our products better.
4channel TPA3255 professional audio amplifier.
2 channel of G6H amplifier has through test, and will apply in our customer professional products , currently we now planto design 4 channel of TPA3255 amplifier,due to TPA3255 has excellent of low frequency performance, we will use 4 pcs TPA3255 chip, each chip independent run in PBTL mode, to improve signal of channel isolation .
For professional occasions using, we plan to integrated DSP unit, strengthened EQ/LIMITER/NOISE GATE function, improves the reliability of various applications, I hope everyone with more valuable comments.
4X500W multi-channel industrial grade 40KHz-100KHz underwater acoustic amplifier
Features:
1) Ultra low noise design, high capacity cooling and setting microprocessor controls temperature and fan speed .
2) Touch press key to select third gear, power failure memory
3) Isolation monitor output
4) Balance of power output
5) Independent power supply and amplifier configurations, high stability
6) Standard 2.5U all-aluminum case design, suitable for rack mounting
7) AC 220V power supply
8) Industrial standard shielded connector output
9) Support RS485 remote control address manually encoding settings
Specifications:
1) Rated power: 4X500W/8ohm pure resistance load
2) Frequency response: 40Khz-100KHz/+/-0.5dB
3) Input sensitivity: 1.7Vrms/high, 3.4Vrms/low
4) Mute setting: enter the relay signal disconnect
5) Protection settings: high temperature protection/over-voltage/under-voltage protection/short-circuit protection/DC output protection
6) Output: transformer-less direct high voltage output
7) Control mode: MCU control channel signal input and channel run, temperature and fan speed
8) LED indicators: run/ fault indicator, low/high /mute indicator
9) Power control: the independent four-channel power switches
10) Communication: RS485 half-duplex communication control, with manual address setup functions, supporting up to 200 from on-line measurement and control
11) Power requirement: AC220V 50Hz or 60Hz 15Amax
authlxl:
Are you still in business?
I see your website is still going, but where are you selling your wares?
Wondering about the g36, how does the DSP programming work? Just through the Sigma studio, or a more streamlined program?
Hello,Kaffimann
so long time in business, few time to discuss the technology here,very busy now, our products have widely used in industry, especialy in high railway system.
G36 and other DSP products have not update now,this product belongs to the minority products, it is difficult to achieve the ultimate.
we will make it later version if we have time, thank you for your supports!
