Creating reference 0V ground
At a quick guess I would imagine the working principle is the assumption that most people don't understand voltage?
The reference point for a circuit is whatever you choose to call the reference point. Having chosen it, you then have to design the rest of the system accordingly. I suppose if someone makes a mess of this then someone else can make some profit from selling them various amounts of compensation circuitry.
I don't understand what "correct the ground zero" means.
Consider any ground loops or even noise in ground is very common and its not to absolute zero it has some value as much as 100s of micro volts or so.
If you take a power conditioner it does conditioning only for Line and Neutral not to earth. Earth is the one which is as much contaminated as the L and N.
Now consider a DC servo method where the signal ground which is connected to the mains earth which is contaminated by either a digital CD player or a hair drier or lift in the house. One way or other its dirty. So what Im saying is look at salas shunt which reduces the noise to as much to nano volts. So there is no treatment done to the ground which is left without any correction. Now thats what Im saying can there by any DC servo which corrects the signal ground to zero? I agree the quality of opamps or Jfets play a significant role.
Thank you for confirming that you are someone who does not understand voltage, and that therefore you are a potential customer for this device. There is no such thing as a voltage.
I didn't bother to look at their website; I didn't need to as the block diagram given in post 1 was sufficient clue that this is pure snake oil. As usual in these cases the only question which matters (in a moral sense) is whether they believe in this stuff or are merely hoping that their customers do.
I'll save you the trouble 😀
The Product Team has made a huge technical leap by combining the Quantum Burn-in Technology’s (QBT) ultra-wide bandwidth run-in signal with the Quantum Acoustics Diffusor’s (QAD) alpha-wave generation technology. From conceptual inception to physical design, the Product Team has succeeded in emitting the 0 - 100 KHz ultra-wide bandwidth QBT signal through the antenna specially designed for QAD. Even though the approach this time around differs greatly with our previous Quantum products, we are sure that upon firstuse, it would not be hard for anyone to discover the versatility and ease-of-use of the new QMT device. The freedom to fine tune your setup is just boundless
This is not a demagnetizer for CDs, mind you that would be crude, it is a quantum harmonizer.
:wave2: stop man stop i cant control laughing. What the hell are these guys doing in Thailand Quantum Mechanics in Thailand? Interesting. When did the Government started to invest in Quantum stuff, they have to be at NASA. Let me get by adress book i know few guys at NASA.:faint:
