Hello there, i have a BX3000T on the bench at the minute. The limit light stays on solid with no output. Ive checked all the transistors and they are all good. Ive proven the pre amp section by using the line out. Unfortunatley i cant seem to get hold of a schematic. What could cause it to go into limit?
Any help is much appreciated.
Rhys
Rhys
Can you give the code number of the poweramp?
It's printed some where on the pcb.
eg. B300 or so...
Maybe I have it...
eg. B300 or so...
Maybe I have it...
Hi, so sorry; that one is not in my data base.
P2502 yes.
Is it a digital amp or analog?
Maybe another can guide you...
P2502 yes.
Thanks!
I've already repaired the amplifier - Behringer BX4500H, which uses the same power amp module P3000.
The schematic is similar to QSC MX700 amplifier, which I used.
Nothing moves you like a hydropneumatic Citroen...
Totally agreed!!
Best regards!
- Live Sound
- Instruments and Amps
- Behringer BX3000T Bass Head
