Hi
I have the Teac UD-301 DAC and i am quite happy with this.
For better sound i want to change the caps:
inside is actually (in the internet you get some nice pics)
at the main board
about 60 pcs Suncon 100µF 25V (green Gold) 105°
about 15 pcs KMG 100µF 25V (dark red) 105°
directly after the transformer
Jamicon 4700µF/25V SK 85° (black)
2x KMG 4700µF/35V 105° (dark red)
Are the (Sanyo) Suncon caps fine, i get nearly nothing from forums about the quality ....good?
I have good sound quality for Muse from nichicon.(KZ and KW) and i have it on stock)😀
What do you think?
kr
Chris
at the main board
What do you think?
kr
Chris
I think changing the caps will almost certainly make no difference to the sound. It may make a difference to your perception of the sound.
These KMG are United Chemi-Con and they are very good(KMG Series - United Chemi-Con - General Purpose | Online Catalog | DigiKey Electronics) at least for power supply.If you track analog signal line and change caps on that with Elna silmic or Nicichon muse es that would be change.Other caps on power supply and other regulating stuff leave it alone,it is good as it is.
Hi
i changed my caps (i mustdo it for my 25 years old Accuphase C200V Preamp) and it was very good that i did this. 🙂its not just in my mind - you can reproduce that change if the other components are the same (other preamp) and other listeners are agree to this change.
nevertheless
i changed all caps with Elna RFS and nichicon series(not all muse series, KA, KW),yes for power supply it is not needed. you are right.
Any objection to the Suncon(Sanyo) and Jamicon??
Thanks for your imput
chris
nevertheless
chris
I highly recommend Epcos/Siemens capacitors LL and Sikorel series. Sometimes they can be found for very cheap. Excellent sounding capacitors.
Hi phaseSomething I would try is to carefully place a sheet metal shield around the transformer.
thx for that ...but its done...😉
next step is to portect the usb Board with a shield housing (i use a steel housing for HF tuners...just 3 Euro..)
bye
chris
Hi 50AE
thanks for that info. i will check this caps.
any hint where you get this? A serious source is for me? mouser......with Fedex is expensive but in 3 day on my desk!
chris
...Admin ...please can you move....
Hi Admin
pleas can you move this thread to DAC (digital line level)?
the project gets bigger and bigger 😀😉😀
thx
chris
Hi Admin
thx
chris
Thats nice idea but remember u must connect every conductive part to chasis like those shield housings.Hi phase
bye
chris
....and better....ok after 50 - 100hours all new caps geting better..I change Jamicon Caps to 105 C Panasonic or Nichicon
are you happy with nichicons?
Hi Basi
Yes i know, the only change to get a good shielded housing is to screw it at the same mounting angle where the usb board is connected to the rear plate.(its on the rear panel where the usb and spdif is mounted.
i made a check after this copper foil session to my reference - DAC Mytek Brooklyn.
the Teac is comming nearer and nearer.🙂
i really like the sound of the BB 1795.
I also testetd the Aune S16 with the AK4495 -its amazing!!!!!!- sounds better than the brooklyn.
Do you think i have to ground the copper foil of the cables too?
bye
chris
Yes of course.if interference rf or whatever came in that shield there must be a way where this interference must go and that way is ground or chasis.Hi Basi
bye
chris
any experience with the total amoutn of hours?
Hi
next question. its generally about the hours of a cap.
If you use during the work week your DAC and Preamps etc in the evening for e.g. 2 hours and on the weekend more than lets say after 6 month you have:
per week 14 hours in operation * 30*6 = 2520hours
Have anybody experience about some ESR measurements or sound changes if the totat amount of hours of the caps are going more than e.g. 2000hours or 10000hours????
its clear. if a dielectricum is comming out of the cap--> than its over with the cap😀
thanks
chris
Hi
thanks
chris
With electrolytic capacitors, I haven't been able to notice any change after 160 hours in low powered circuits like preamps, DACs.
This is using a frequency analyzer and pink noise.
...sorry...dont mix two topics
Hi to all
sorry it is maybe too confusing
1. is my project "pimp my DAC -Teac ud301
2. generally discussion about the caps and the lifetime
ad 1
yes the actually caps are partly fine (Jamicon i should change in the first step)
and all other thinks it will come - step by step
ad 2
every manufactor give you a datasheet with his "warranty" 😉 that the cap is under special condition like its written. ok clear.
but if i look at the lifetime - the hours - than i have to think about the device running time. ok?
so my question:
if you use your device (DAC, preamp, "no DAC") for some month, eg. 12-18 month, and you are enjoying your music - Has somebody make some tests about new caps and existing (old) caps ?
Hi to all
ad 1
ad 2
so my question:
...update...its not easy
hi
the next step is the housing of the USB board. Its not easy. nothing is fitting....😉
My idea to fix it on the rear panel is obsulete becuase the connectors on the pcb are too big and have to be closed to the rear panel. otherwise i cannot plug in.
so its ongoing...
hi
so its ongoing...
- Design & Build
- Parts
- Pimp my DAC - new caps
