How to correct wire 2 woofers and 1 tweeter to 1 stereo (2ch.) amplifer?
It will like like that Screenshot by Lightshot
Based on the limited information provided, I assume that you have two random woofers, a random tweeter and want to make a center channel speaker from the lot. Is this correct? If not, what are your goals?
Do you have the drivers? If so, make and model numbers?
You will need a crossover, passive or active which will drive your "wiring" choices. System goals are needed to give any meaningful l advice.
Yes it's looks exactly like center speaker, but it will be Bluetooth speaker.
Speakers I'm planning to use is 8ohms.
Two woofers in series plus low-pass filter, tweeter with high-pass filter, to make a complete loudspeaker.How to correct wire 2 woofers and 1 tweeter to 1 stereo (2ch.) amplifer?
Bridge the two channels of the amplifier to make a single channel (mono) amplifier.
Connect the loudspeaker to the bridged amplifier.
Agree with Sonce - although the amp may not be bridgeable. Check specs carefully.
If the amp is not bridgeable, and is 4 ohm stable then parallel the woofers with a low pass filter and high pass filter the tweeter and connect to one channel. Use the other channel to drive a subwoofer, maybe.
BobEllis, good idea also, but as proposed it will not play the content from the other channel (if the input signal is stereo). No problem, before the amp summation of the input stereo signal to mono must be done, with Y resistor "network" or so.
Sounds like a job interview question, but in your case perhaps it's a parole board hearing question, since you must not have access to another tweeter to save your life?
On your behalf, please let me take up a collection so you may have a matched pair?
I'm in and would be happy to donate some GRS Mylar tweeters.
- 2 woofers and 1 tweeter with 1 stereo amp. How?
