Apex SB 3.1 Preamp
Ok so i have built the Apex SB3.1 Preamplifier. The problem is that the multimeter reads 10 Volts at point A and B. It should read 24 volts as indicated in the diagram.
Any idea why is this happening. I am using a 15-0-15 ( 1 Amp ) transformer. The transformer ground wire ( center tap ) is unused and the preamp is fed from the remaining 2 wires.
Reactions: 1 user
You must use transformer 24-0-24. You must connect center tap to gnd and you can use transformer 15-0-15 but you must relace 24v zeners with 15v zeners. This PCB have mistake... you can fix it use this pcb.
Reactions: 1 user
Thanks for the reply. Apart from using a 24-0-24 transformer and connecting center tap to ground. Is there any other change that i need to do in the circuit ?
Reactions: 1 user
With a wrong polarity it looks like the transistors collector is an emitter and the emitter a collector.Like that it still works at low voltages but with a very low current gain.But at higher voltages (>7V) the base-emitter juntion acts as a zener diode with possebly high currents destroying the amp.
Mona
Reactions: 1 user
