Do any of these inexpensive good sounding DAC's have an USB input?
Sure...even network input 🙂
Thanks Murata for taking us through all this, it's been quite an informative journey 🙂
After being through multiple setups with 8-way horns, expensive GOTO drivers, down to 3-way with AER widebander. Inlow Spiral Basshorn to ported box and then back to Spiral, I think we can conclude that you finally found the sound, that floats your boat, congrats.
There has been many inputs in this thread, to what design, is superior to the other and everybody has their own taste and choices, be it OB, boxes, horns, ported bass ect. Not even to mention drivers, dynamic, planar, compression.
My point here is, that many topologies can sound terrific even spectacular, IF implemented correctly, which is important to recognise.
You, yourself also recognised that with the Spiral Basshorn, which was first dismissed only to find out that the x-over was wrong and with the right setting, everything fell into place.
So again, correct implementation of chosen topology, is crucial.
On that note, I myself, find a correctly implemented setup of horns (I play on 4-way active with DSP), superior to other designs and it is not only floating my boat, but also rocking it 🙂
Regards Sebastian
Regards Sebastian
Regards Sebastian
Thank you, Sebastian, for warm words.
Yes, implementation is important, but some limits of each approach are also exists.
Digital crossover is good to easily implement high order x-over, but the obvious limit for me is quality of DAC.
Another limit is restriction to use analogue sources.
I'll miss my 5-ways 🙂
Just discovered that thread.
Wow, that is some badass project. Congrats.
Just sold my 210-10D and my Voxativ AC-1.6, i guess we're all huntin' the unicorns at some point, is it ? 🙂
Just sold my 210-10D and my Voxativ AC-1.6, i we're all huntin' the unicorns at some point, is it ? 🙂
Try AER - it is "end of the road" driver 🙂
Listen to the single one recorded by iPhone:
https://www.youtube.com/watch?v=jNN9LbKbBG4
Wow! I have replaced my 21" ported sub with this:
So, now I have 5 ways speaker system with 4 of them for bass! Extraordinary🙂
Try a bass line array from the top of the room to the floor.
Crossed at 50hz.
You will like it.....
Crossed at 50hz.
Crossed at 50hz.
I also think so, but for now I'm happy with this device crossed at 45hz with 24db/octave slope. It has some technology to control displacement of the cone, kind of feedback. It helps to dramatically decrease distrortion. For below 50hz it is really good solution.
Hu SystemaMurata,
What is this sub?
Thanks!
Best regards
Peter
What is this sub?
Thanks!
Best regards
Peter
Hu SystemaMurata,
What is this sub?
Thanks!
Best regards
Peter
Velodyne DD-1812
Unfortunately many links to pictures and audio are not working now.
But my YouTube channel is still alive 🙂
Latest 6-ways:
https://youtu.be/pu_dpaKZczA
Latest full range:
https://youtu.be/sCA9f1MZhv8
Latest 6-ways:
Latest full range:
Latest additions to the system is in electronics field:
New SE EL12 pentodes for bass region driving huge 25hz horns.
So, now I have perfect SPL down to 50hz with 3 SE pentodes driving 3 channels - AER and 2 bass GOTO drivers. And subbass managed by Velodine DD-1812 with 40hz 6th order low pass embedded crossover.
Next challenge now is to choose best volume regulator (passive preamp).
I found that transformer sounds much better in my system that resistive.
I got Luxman, Music First and some local vendors.
I really enjoy following your adventures.
One question: What is the tune playing in the youtube video where you record your friends TAD setup?
My friends 4ways TADs
Johan
Johan
Johan
Thank you 🙂
It is my favorite composer's Shostakovich Quartet N8!
- GOTO 6-way TimeAligned Horn System
