DVD 5910 Laser replacment help?
I got a dvd 5910 to use for dvd-audio and redbook cd playback but the laser is bad. does anyone have experience/tips for replacement of this laser? (I found a youtube video of a guy replacing a laser on a dvd 2930, so I bet it will be similar, but he had a hard time getting the laser adjusted perfectly so I thought I would ask first.
God bless...
Mark
all the denon
5910
3910
2900
2910
use the laser
HOP-1200S
I have the two players denon dvd 3910 and denon dvd 2900
And switched between them the laser Without problem.
If you buy a new laser
Make sure you remove the shorted solder bridge from the new laser
Hi dazz,
Thnks. I did order and install the hop1200s laser (and I removed the solder from the two spots). On your 3910, does your mechanism start spinning right away and keep spinning? (If you look at the youtube video you can see how my 5910 is acting)
God bless...
Mark
Hi dazz,
God bless...
Mark
Mark
There are a few things you should check
1 Is SACD discs workers
2 Are Disks DVD workers
3 Is the CD workers
Concrete example
In my case about my project on the DENON 3910
One of the change i do in the audio circuit
I removed the SN74LV157 ( Data Selectors )
As a result of the PURE DIRECT circuit
did not work.
And CD discs did not work. and dvd\sacd work
I returned back to the SN74
To circuit
And discs of the CD worked.
My experience on my own projects
2900
And
3910
Not always what it really meets the eye is the problem
