Try this..... Cheap, simple to build, sound is superior compared to many megabuck preamps. Line level only, gain is about 12-14x, drives 15-22 k loads with ease. Those russian tubes linger around everywhere for a few dollars a piece.... If you need, I have phono (MM) schematic too with the same tubes.
as a preamp junkie, I can tell you sanyo plus is the best I ever tried
followed by some onkyo integra and nikko, ps audio and some parasound
The BF862 single ended preamp by Juma sounds fantastic and easy to make.
http://www.diyaudio.com/forums/pass-labs/146310-bf862-preamp-48.html#post4925674
How much work are you willing to put in? Something like a Yamaha C-4 is a darn good preamp, but may appreciate addressing age-related woes. Also, the headphone output in this model is less than ideal (very high gain, high output impedance, and temperature compensation looks suspect even for a Class A job).
Both amps are very good.i don't know how sound yamaha c4, what could you say about ?
what about : audiolab 8200q ?
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_c4_schematic.pdf
https://www.hifiengine.com/hfe_downloads/index.php?audiolab/audiolab_8200q_service.pdf
You will have to register for download.
thanks and what do you think about MUSICAL FIDELITY a3.2 CR compared with the both above ?
- Analog Line Level
- Preamplifier for Rotel RHB 10
