Some folks expressed interest in seeing the slides from my Burning Amp 2016 presentation of the Hafler DH220C revamp using a full-complementary JFET input stage with a floating tail. It is a powerpoint file, and, unfortunately, it is over 7 MB, even zipped (zip compression of ppt files is negligible). I don't know of any easy way to post it here. Please email me if you would like a copy.
Bob
You should be able to "save as" or "print to" pdf, which is much more portable 🙂
Sent from my iPhone using Tapatalk
Bob
Dropbox is an easy way to share files.
400k file and its perfectly fine.
good that export-to-pdf was the easy win 😉
it goes to show: rarely is it a good idea to use microsoft file formats to share files to the world. pdf at the resolution you used was perfectly fine.
cheers
cheers
Hi guys,
Here is a PDF of the slides, thanks to Mark Johnson.
Bob
Thanks for share.
Happy new year for you.
Happy Christian new year for Dad and the rest of gentlemen of this fantastic community.
Thank you for all your efforts to get these posted.Hi guys,
Bob
You used 489 and 689 dual jFETs.
Can k170/j74 be substituted? or k389/j109?
What performance would deteriorate with this substitution?
Was great fun to be there as Bob summed up the specs he'd gotten after following thorough the process! Not Bad! 😉
In principal, these substitutions can be made in this architecture with appropriate changes to some passive component values, especially the tail resistor. However, there is little benefit unless you already have those parts hanging around (most are no longer available). A key issue is that you really want dual monolithic matched pairs for the P and N JFETs. The hassle of matching and changing component values is probably not worth it. Although the parts you mention have somewhat lower voltage noise, the net reduction in noise by use of these larger-area JFETs is not great, since there are other contributors to noise. Moreover, with the LSK489/LSJ689, the amplifier already achieves very low noise for a power amplifier. The larger-die JFETs, like the k389, also have much higher capacitance.
Bob
Thanks for that.In principal, these substitutions can be made in this architecture with appropriate changes to some passive component values, especially the tail resistor. However, there is little benefit unless you already have those parts hanging around (most are no longer available). A key issue is that you really want dual monolithic matched pairs for the P and N JFETs. The hassle of matching and changing component values is probably not worth it. Although the parts you mention have somewhat lower voltage noise, the net reduction in noise by use of these larger-area JFETs is not great, since there are other contributors to noise. Moreover, with the LSK489/LSJ689, the amplifier already achieves very low noise for a power amplifier. The larger-die JFETs, like the k389, also have much higher capacitance.
Bob
I already have matched pairs of k170a, b and bl and matched pairs of j74bl. I don't have j74a so am stuck with using the higher Idss grade.
I think I am interpreting your reply to mean there should be no deterioration in performance if I make that current change. Instead of 4mA what do you suggest? 5mA, 6mA? or to a lower current?
Thanks for that.
I already have matched pairs of k170b and bl and matched pairs of j74bl.
Although the larger die devices can be optimally operated at higher tail current, the safest thing to do is to adjust the new tail resistor to achieve the same tail current as before. A smaller value for the gm-equalizing degeneration resistors might be appropriate due to the larger overall gm of the stages (the larger die devices produce somewhat higher gm for a given operating current), but I'm not sure by how much.
Bob
OK, I understand.Although the larger die devices can be optimally operated at higher tail current, the safest thing to do is to adjust the new tail resistor to achieve the same tail current as before. A smaller value for the gm-equalizing degeneration resistors might be appropriate due to the larger overall gm of the stages (the larger die devices produce somewhat higher gm for a given operating current), but I'm not sure by how much.
Bob
This could end up going into a set of Sugden P128 which uses 2pr of LatFETs.
EUVL posted info for j74 Pch degen that I have saved.
Nelson had them at Burning Amp last year. The drivers are one off prototypes from Denmark. The fellow who made them didn't get funding for production.
The cabinets are Parts Express, I believe the .58 cu ft model. They seemed to be sealed.
You can find the new units from SAL here: Home
A couple of pairs are in the store:
https://diyaudiostore.com/collections/loudspeaker-drivers/products/sal-08c08-loudspeaker-drivers
Papa Pass should soon have some info on the simple boxes he has them in , and any filters he uses.
I think sealed .75 cu.ft. Cabs from Parts Express and will have an open baffle design at some point.
Probably should start a new thread I guess..
- Member Areas
- Clubs & Events
- Burning Amp 2016
