Is there any triode spice models that can be used in Circuit Maker 2000?
What spice engine CM is using and what models?
the spice models I need:
ECC88(6DJ8)
ECC81(12AT7)
6N3P(2C51)
I got all of these models, but I can`t use them in CM 2000.
ECC88(6DJ8)
ECC81(12AT7)
6N3P(2C51)
I have circuitmaker 2000, and this works for me
* 6DJ8 Spice 3F4 model
.SUBCKT X6DJ8 P G K
Bp P K I=(0.06867321543e-3)*uramp(V(P,K)*ln(1.0+(-0.03262478644)+exp((7.453794563)+(7.453794563)*((31.84399594)+(-13.80505589e-3)*V(G,K))*V(G,K)/V(P,K)))/(7.453794563))^(1.37713474)
C1 G K 3.1E-12
C2 G P 1.4E-12
C3 P K 0.18E-12
.ends X6DJ8
another version
*Vacuum Tube Triode (Audio freq.) pkg:VT-9 (A:1,2,3)(B:6,7,8)
.SUBCKT X6DJ8a 1 3 4
B1 2 4 I=((URAMP((V(2,4)/31)+V(3,4)))^1.5)/120
C1 3 4 3.1E-12
C2 3 1 1.4E-12
C3 1 4 0.18E-12
R1 3 5 10E+3
D1 1 2 DX
D2 4 2 DX2
D3 5 4 DX
.MODEL DX D(IS=1.0E-12 RS=1.0)
.MODEL DX2 D(IS=1.0E-9 RS=1.0)
.ENDS X6DJ8a
12AT7:
.SUBCKT X12AT7A A G K
* ANODE MODEL
BLIM LI 0 V=(URAMP(V(A)-V(K))^ 1 )* 0.0037
BGG GG 0 V=V(G)-V(K)--0.5
BRP1 RP1 0 V=URAMP(-V(GG)* 0.09869 )
BRP2 RP2 0 V=V(RP1)-URAMP(V(RP1)-0.999)
BRPF RP 0 V=(1-V(RP2)^ 1 )+URAMP(V(GG))* 0.1
BGR GR 0 V=URAMP(V(GG))-URAMP(-(V(GG)*(1+V(GG)* 0.012937 )))
BEM EM 0 V=URAMP(V(A)-V(K)+V(GR)* 45.093 )
BEP EP 0 V=(V(EM)^ 1.4 )*V(RP)* 0.00000863
BEL1 EL1 0 V=URAMP(V(EP))
BEL EL 0 V=V(EL1)-URAMP(V(EL1)-V(LI))
BLD LD 0 V=URAMP(V(EP)-V(LI))
BAK A K I=V(EL)
* GRID MODEL
BGF GF 0 V=(URAMP(V(G)-V(K)--0.5 )^1.5)* 0.00012
BG G K I=V(GF)+V(LD)
* CAPS
CAK A K 0.0000000000004
CGK G K 0.0000000000023
CGA G A 0.0000000000016
.ENDS X12AT7A
don't have anything for the 6N3P
Other models I do have are at:
http://home.netcom.com/~wb2jia/tubes/spice.txt
http://home.netcom.com/~wb2jia/tubes/spice2.txt
http://home.netcom.com/~wb2jia/tubes/spice3.txt
http://home.netcom.com/~wb2jia/tubes/spice4.txt
.SUBCKT X6DJ8 P G K
C1 G K 3.1E-12
C2 G P 1.4E-12
C3 P K 0.18E-12
.ends X6DJ8
another version
C1 3 4 3.1E-12
C2 3 1 1.4E-12
C3 1 4 0.18E-12
R1 3 5 10E+3
D1 1 2 DX
D2 4 2 DX2
D3 5 4 DX
.ENDS X6DJ8a
12AT7:
* ANODE MODEL
BAK A K I=V(EL)
* GRID MODEL
* CAPS
.ENDS X12AT7A
in any of these programs you should take the Model and back into the curves in the RCA tube handbook (or other). The Koren models work well but they are in need of adjustment of some of the variables to acurately portray what's cookin down there in ECC83 land.
I think wa2ise is my saver. I use circuit maker and I do not understand an indication in the spice data, so I can not create a new model of valve.
If I take your:
C1 3 4 3.1E-12
C2 3 1 1.4E-12
C3 1 4 0.18E-12
R1 3 5 10E+3
D1 1 2 DX
D2 4 2 DX2
D3 5 4 DX
.ENDS X6DJ8a
first line: 31 is the ampli factor : ok?
but what is 120?
c1/2/3: the capacitors
R: the ri of the valve
thanks for your help
If I take your:
C1 3 4 3.1E-12
C2 3 1 1.4E-12
C3 1 4 0.18E-12
R1 3 5 10E+3
D1 1 2 DX
D2 4 2 DX2
D3 5 4 DX
.ENDS X6DJ8a
but what is 120?
I found some models I needed and also found the explanations I was looking for. So I can save them in my circuit maker.
But: edit macro; Save macro, expand macro, and macro lock do not work. These positions remain grayed out.
Only new macro; Macro utilities etc work.
What can I do ?
What can I do ?
I simply open "triode.sub" with a text editor and add a model. Attached is my file with much more accurate models than the one above. Feel free to grab the ones you need.Hi,
What can I do ?
What do you mean by "cannot read it"? You can't open it in a text editor like Notepad?Many thanks
I have extract the zip but I cannot read it.
ok groucho, I don't why I do not know why it did not work????
now what is the procedure for introduce the datas in circuit maker?
the informations in the tutorial circuit maker are grey and when I try to modify the existing datas, a window open with '' only to read ''
Forget the tutorial. Just copy and paste the models you want from the "triode.sub" I posted to the triode.sub in your "models" directory.ok groucho, I don't why I do not know why it did not work????
If running Windows 10, then that may explain problems re read only. To add data to TRIODE.SUB, I have to copy it elsewhere and then work on it with Notepad, then save and copy it back and over-ride the original TRIODE.SUB file. That worked for me. Now I can add new data to SUB files using that method, even remove stuff I don't want. Hope that helps?
Hello,
I sorry for my late response but I was missing + computer problems.
Yes it is Windows 10.
I do not find TRIODE SUB. Yiu can see on my copy the TRIODE that I registered in MODELS. That oes not work.
I dont find anywhere a ''SUB'' file in the Library or models...
Thank you for your help
- Tubes / Valves
- Triode spice models for Circuit maker
