DEF Amp
The one and only
Joined 2001
I am going to start this thread around the circuit shown at BAF 2016,
seen at the end of the talk on the video, and attached here in simplified
form.
I am calling it DEF, which stands for Depletion / Enhancement Follower.
It is a self-biasing push-pull output stage which has some interesting
characteristics, not the least of which is low temperature drift which allows
stable undegenerated operation.
:wiz:
Reactions: myfirstamplifier
...I am calling it DEF...
Eh?? 😛
Very interesting, though it will be a challenge to find enhancement P-channels whose Vgs matches that of available depletion parts... The IXYS parts all hang around -2V for reasonable bias (<2A), so maybe the 2SJ201 could work. The USCi and Infineon JFETs all require very negative (<-7V) bias, though. Perhaps, once again, the Semisouth part is just special...
Thanks Nelson
I knew there was a reason to hold on to those R085s 😀
Standard PSU is already available 🙂
Thoroughly enjoyed your talk. As always learned a tremendous amount and it was a real pleasure to listen to this amp
@ Mr Pass
In follower V2 resitors help selfbiasing for unmatched part's
do they resistors other function in the same time ?
Example schade feedback on enhancement IRFP240 for triode like character ?
@ Mr Pass
Hello soundhappy. You made an interesting point. A follower using an N device which has a pentode-like characterisic [R085], and P- device which has a triode like characteristic; be it a Schaded FET or a SIT; say 2SJ28. What will the resultant subjective sound be due to mixing a pentode and a triode characteristics?
...... It is a self-biasing push-pull output stage which has some interesting
The low temperature drift only occurs when the Id-tempco of the PMOS is smaller than that of the NJFET, correct ?
Am I right in saying that it will have more noise than e.g. a Source Follower using a matched pair of NJFETs ?
Patrick
