Like the title states, I'm looking for the schematic for this. I picked one up for near nothing so I think it's worth fixing as long as the parts are available.
It's a dead short somewhere as the fuse lights up like a bulb when it goes.
I pulled the power connection between the transformer and the board and the fuse isn't blowing anymore. Getting good voltage from the transformer. (5V from one leg and two 48V[center tap it seems])
There is no visual issues other than the two main power caps have leaked a little. Pulled and metered them and they're close (~9100uF ea, rated at 10000uF)... So right now I'm starting to go through/draw out the circuit starting with the power supply.
hoping anyone here has had this issue and can offer any suggestions (or better yet a full schematic 🙂)
I did get a partial schematic from this thread; http://www.diyaudio.com/forums/soli...mplifer-thermal-compound-okay-power-ic-4.html
any suggestions are appreciated.
Vin
Vin
Looks like I caught a break. While tracing the circuit and metering continuity I found diode D704 is a dead short (not a visible mark on it). using earth I verified that the chip isn't shorted based on the pic from the thread I linked. only Pins 11 and 14 meter to ground.
The Rectifier Diodes P300D aren't that available but I've crossed it to a 1N5402
P300D; http://www.vishay.com/docs/88691/p300.pdf
1N5402; http://www.vishay.com/docs/88516/1n5400.pdf
Only real difference I see is the reverse current is higher on the 1N5402 vs. the P300D
In the morning I'll get a new set or Diodes and Caps and report back.
Vin
Vin
New regulator Diodes and it's up and running. There's something wrong with Channel A, when turned on the sound drops out and it sounds like it's in a hall.
Channel B on it's own seems to work just fine.
Going to start looking at the channel switches after work today.
Vin
Vin
Look for bad solder joints on the A output terminals, seems like your ground is getting lost there.
Good call... Channel A Left + and Channel A Right - contacts were both broken...
This amp had a hard life before I got it.
Did some testing and it's outputting 129 watts 🙂 But the fan isn't running well 🙁
Looks like an 8V DC supply, also wonder what the driver circuit is and wonder if it would be better to have it run a little more sensitive..
Vin
8 V DC? Never seen a fan like that, guess it's a 12 V job? Looks like an axial, but a bit of an oddball shape, rather deep. 50x50x32 or something? I'd try salvaging the bearing on the old one first. It often says what it is on the label, a sintered bearing would require different oil than a standard sleeve bearing or ball bearing job.
HFE has a SM for the SU-G70, maybe that'll give you some hints?
Ya, found that odd as well. when the fan is on the supply voltage is 7.98VDC and doesn't change or ramp up. I plan on taking the motor housing apart shortly to see what it really is.
Vin
Vin
Part number on the motor is MDM-4RB4MXA. I can't seem to find any specs on it and I can't find any info on what this motor really is. from Panasonic's site it's been discontinued.
The replacement seems to be this one;https://www.encompassparts.com/item/414723/Panasonic/MDN-4RB4MRC/Motor
I put a drop of sewing gear machine oil on the shaft bearing and it helped immensely.
Running it on a separate supply for now to see how it behaves.
Vin
Vin
- Technics SU-G50 - Blowing Fuses - looking for a schematic
