I was presented by my Ukrainian friend of this tube. I had search on the net about this tube and this are my reference. Now my question is, where i can make use of this tubes?
I'm Planning of a signal splitter aside fom tube pre-amp with two anodes tied together. Can they make a good signal splitter in triode or pentode mode?
What other applications they may be, Any help will be much appreciated.
Thanks..
jun
Thanks..
jun
Thanks..
jun
If the curves are real, you can make nice SPUD amp (in triode).
Ua=240V, Uk=-4V, Ik=31mA, Pout = 2W, THD=4%, OTR=5K
With this, I must tie the 2 anode to make a spud amp. Thanks, this is one good option.
How about for a driver or preamp..I can't find triode curve for individual anode?
I would like to see a proper translation of the data sheet, as this is a small tube which I doubt would be capable of 7.5W triode dissipation.
I have attached my trace of the tube in triode mode with a 3W dissipation line.
I even put a tube on the tester (Avo VCM) and it runs VERY hot at 150v and 20mA on a single anode.
wow that was a nice idea..
How about using it as a driver or as dual output preamp for Bi-amp or the like?
You may use it where you use 6Ж9П, 6Ж11П, 6Ж51П, or similar tubes. Also, as a half of 6N6P/6N30P, when triode strapped.
Thanks Wave... i have amps using 6J11P-e driving 6C33c SET and 6N6P driving 6P3S-E PP..so i will also try to use them and see.
Finally I am seeing a good use of this tube...
- Tubes / Valves
- Russian 6J43P-E(6Ж43ПE) Dual anode pentode....
