GU-50 opt in europe
Some nice transformers are made by Indel in Poland. Have used these with very good results. For 2X GU50 in PP, the TGL40/001 would suit you good, and for 4X in PPP, TGL60/001 or 002 are fine. The later for 4 ohms load, the others for 8 ohms. The tube GU50 needs about 4-5 kohm in PP, and about 2,5 kohm in PPP. In Europe it is convinient to buy these transformers from Transfer Multisort Elektronik - Electronic components, and they have powertransformers also. Here are some schematics also:
Röhren-Verstärker mit der LS 50 (GU 50)
8-10k for PP, 4-5k for PPP
Wavebourn was your Amp running on BAF?- have read and seen pics- now i wait for some
clips.
Yes, but it was not a GU-50 amp.
Nice,
the GK71- heating current eater ;-).
Was it a good meeting with Fritz Speaker- good playing set up?- all Dynaudio Chassis?
Some years back i could listen to 833 (Silvercore) and PHL+ TPL Bayma AMT (Aschenbach)- very impressing.
Nice,
SMPS
Do you mean my amp? No, made completely in my garage.
I have a similar 813 amp too, but GK-71 are more powerful. And yes, thanks to local feedback around output tubes it was driving Fritz speakers elegantly!
Ah, SMPS- elegant solution.
I only have build with given schematics- little SE Amps with PCL86; EL34(6P3S/-E; 6AS7;KT-88.
Since last year i swapped back to ss builds.
The bigger Tube Animals with HIGH Voltage makes me a bit scary, but much liked by optical view.
Nice to read that it is enjoying 'partnership' Fritz Speaker and the GK-71.
Have to watch more back in Valve Tube.
Where is FLT now- find a solution, any ideas?
an EL34 uni Amp
I have build a EL34 with EF86 SE last winter.
Also tested with 6P3S(-E) and 6P7S(oktal to 807- for lower Plate Voltage)
For use 6P7S you must change two wires on socket, one to Anodecap.
It has a slightly +6db high and low pass correction- and worked super.
The best it has a bias point via little lamp.
With all this tests at last i have a bad grounding contact and seems one OPT
is failed- 6P7S only one channel- the other is sending piping tone to speaker-
that's bad.
All info you find here.
Funk - u. Fernmeldetechnik
Well, it depends on the plate supply voltage, see here, page 9. E/FL152 and GU50 can be considered as equivalents, as both are sucessors of WWII RL12P50 and LS50 of TELEFUNKEN fame.
Well, plate voltage and load impedance depend on power/distortions ratio that you prefer. LS-50 was designed for mobile operations, with low filament power. It can't deliver as the result adequate current on low anode voltages.
I received an answer from Mr. Ogonowski yesterday. Very quick, very interesting.
80W or 100W; normal EI core and amorphous C-core. Of course amorphous core
costs more than standard iron...
Now it is my decision...
I dont think that one can hear any difference between 80 and 100W.
Wavebourns pyramid has 80W and it should be enough to make your
neighbours angry.
As for amorphous core: price is about tree times the standard core iron.
I know it is worth it, but right now it is a bit too much.
