100W Ultimate Fidelity Amplifier
Sorry for not getting it - but where does the pot selector drive circuit connect to the above analog switch circuit?
Thanks.
hi
do you test this one swich?
is this worked perfect without bad quality in output sound?
I am thinking of building this on veroboard to test out. BC550/560's are some of the finest small signal BJT's used in many state of the art low-noise, low-distortion pre-amps so I suspect they do not degrade the signal when used correctly.
I wonder if a LED and 4.7k in series resistor can be used to give visual indication of which switch is active?
You may find that jFETs work better for switching duty.
There was a Thread some years ago in which was mentioned an alternative switching arrangement that eliminated the distortion due to any non linearities across the switch.
I wish I could remember these things !
