I never had a linear trackingTT but I had a friend long ago with a Thorens turntable with Rabco arm which always looked so cool when we were kids. So my question is on one of those turntables is the stylus at the tangent point of the record or is it offset from that point? How does the difference in the radius of the track from outer to inner track affect the stylus as the record is playing, is it superior in some way to a standard pivoting arm or only in regards to anti-skating?
The Rabco is set up for zero overhang, and is intended to be tangent and perform the same at any radius.
The tracking error is often worse across the playing area than with a pivoted arm, since it constantly
hunts back and forth from zero with active correction (in one direction).
http://lcweb2.loc.gov/master/mbrs/r...Servo-Driven Straight Line Phonograph Arm.pdf
Thanks Bill. I'll read the paper just for sh*ts and giggles. 🙂 I doubt I will ever have a system like John talks about with everything perfected for vinyl. Just learning how to align the new Ortofon cartridge I got for my old Technics SL-Q2 table with what looks like only one place to do anything, the rotation around the mount center-line, and get it right would be nice. This turntable has been sitting for literally almost 20 years. The kids decided when young that you could play a CD on my TT and wiped out the stylus. I figured I'd wait until they were grown up before I ever replaced the stylus. Now I can fix it and listen to vinyl that has been sitting as long as the table. I never had to do any of this stuff as my brother-in-law did all that for me back then. All I can see is that you can turn the cartridge around the mount since there is no separate head-shell and get the stylus perpendicular to the vinyl. I guess one of those test records would help but I've never seen or heard one. :deer:
Well idlers are in vogue now amongst some. I suspect with work you could make the Dual rather good. But all I know about idlers is:
-Garrards go for stupid money
-Thorens go for silly money
-I should have picked up a lenco when they were cheap 2 years ago.
Like many I was put off idlers by experience with a Garrard SP-25 decades ago.
Bill,
Unlike the Technics I would imagine I will have to put some real work into the Dual TT to get it working again. The grease is probably dry and I can imagine that anything rubber that has been sitting in one place all this time has a flat spot. So I'd truly have to disassemble the TT and clean that all up, the direct drive Technics will just work.
And that is where you might be wrong on Azimuth. The optimal position for the stylus might leave you a channel imbalance in the coils but one of the main benefits is optimised stylus friction. channel imbalance can be adjusted for after all.
Fascinating how many things have been forgotten since the late 70s.
No, no I'm not. The coil can be slightly loaded offset and still perform, where as if the tip is far off you'll literally not have anything play to one side of center that you can really hear. The tip has to make contact for there to be music, and nothing can change that. Having a more balanced coil cannot create signal where there is none. Besides most cartridges are fairly tolerant since they're made to move a fair bit on suspencion.
