DIY STK-0050 module.
Dear compatriot:
I searched a lot, there's enough info on the web but I have not compiled almost nothing. I found a schematic and someone who manufacture a replacement very well done, attached photo, but I did not find the drawings of the PCB.
Really disappointed me a little and leave the subject, but I still interested.
If anyone has more info is welcome and refloats the post.
Regards!
  • STK-0050_sch.pdf
I have an old sx 780. one channel blown STK0050II on other channel.
you can replace the STK with an IRFP240 and IRFP9240 with 6.8v bias zener
they are much better and an 82pf cap replaces the 10pf stability cap
sound is much better. The amp circuit is very close the the Ultimate amp circuits in other threads here.
I am thinking of replacing the TA7136p with a 6922 based tube preamp. that should make it competitive with $2500 equipment.
Thanks for the info, could you be so kind as to share with us an schematic of how to connect the two IRFP transistors and the zener diode in order to replace the STK0050 module? Regards, Andy
I have STK datasheets and a pic of one I took apart.
The old ones in the 1980's did sound quite good, but bonding wires always breaking off.
  • Sanyo STK family datasheet.pdf
  • Sanyo STK family app note.pdf
