PCB coating
I wanted to know what is the green color coating that is done on the PCB called as? Is it to prevent oxidation of copper??
I have etched my own PCBs using toner transfer method.Is it really necessary to apply the green coating on the exposed copper?
Thanks.
The coating is called solder resist and is applied by screen printing. It is not practical to apply to homebrew boards unless you have screen printing facilities and a mask for the resist pattern.
It is not essential, just nice to have.
Measures to minimise copper oxidisation are tinning the board either by hand with a soldering iron (tedious) or tinning solution, or spraying 'conformal coating' over the finished *assembled* board (copper side only!). I've no idea how much grief it is to rework a conformal coated board though.
Rework
Most conformal coats are fairly thin and I just solder right through it and then after cleaning off the flux, give it a touch up with a spray can. The only bad part is the smell of vaporizing conformal coat. I suggest not breathing it.
If I don't have conformal available, I just use clear spray paint.
can i use a lacquer base spray paint? or there is specific type of spray paint? cause i don't like clear coats.
For the component side, you can spray whatever sticks on resin based materials; a primer for plastic car parts (bumpers) will often do the trick.
Then the final paint: it depends. If you intend to deflux the board after finishing soldering, which often results with the deflux entering the component side or at least the board edges, then not all spray paint will resist. 2-component paint is of course the best (and industrial soldermask is, I worked in a PCB factory years ago), but some spray paint will last as well. Better test it on a test piece before if the final paint resist deflux.
For the solder side: no spraying before soldering has finished, as it would avoid proper soldering (or even disable it).
What I do is painting the component side (with primer) first, then solder everything in place, deflux, the put special protective lacquer on sodler side.
Or: order your own PCB design from a PCB service, nicely soldermasked on both sides, even with component marking. Prices have come down a lot !
To come back to the original question (is it required for howbrew projects): yes, for the solder side. If you don't deflux the solder side, followed by a protective lacquer, then the solder and cupper traces will start corroding over time (as the flux is acid), eventually causing shorts, etc.
