SoundStream 1000S Schematic Diagram
Does anyone have an alternate schematic diagram for the Reference 1000S that has the following (attached) circuit board designations for the high-current/power switching circuit?
The one I have has the designations and values shown which aren't the same.
Do you still need this other schematic Perry? I have 2 for this amp. The other one looks like the one you were looking for. Lmk if you'd like me to email you the schematic 🙂
if you wouldn't mind, i could use the alternate schematic as well. i have a large collection of s/sx amps, and if i recall, there were 3 different variants when i was going through them. it's been a few years, but i might be running through them (or the rest, i should say) again this winter and would appreciate it.
djheathen@gmail.com
Tanks in advance, Heath H.
yes, the 500/700/1000 s/sx amps are all quite similar, but also vary, even within the same exact model. for instance, i recall a resistor between the regulator and torroid having quite different values, as well as auto hc circuits, which, iirc, can vary between amps that have the feature. i have used the diagrams interchangeably, but for some things, i needed the specific diagram...... if that answers your question.
