a bit on loss.
Apparently you missed the 40 years mark.
A small observation :
- the term 'science' is most frequently used by non-scientists
- the more often the use, the lesser the chance it's a scientist
- if it is a non-scientist who uses the word, the higher the odds it's an excuse to hide behind for lack of a veritable argument.
DBT has been just about the only subject you've posted about in the last 9 years.
Would you like me to tell you how many times you've mentioned science, or a variation of the word, in the course of close to a decade ?
It is a poor response when a student asks "why are you teaching something which is different from the textbook?". In this case, the student ought to tell the prof to go and read the textbook although this will not make him popular with the prof.bear said:This is the typical response from many professors who tell their students to "go read the textbook, and come back when you have a specific question". It's a poor response when professors give it, and no better here.
It is a good response when the 'student' wants the prof to read the textbook for him, tell him exactly which parts he needs to learn parrot fashion, and then drop big hints about what questions will be in the exam.
My understanding is that the broad parameters for high fidelity sound reproduction were established in the 1950s, and have not changed much since then. If I wanted to know the actual numbers I would use Google. The reason they have not changed much since then is that good experiments seem to confirm that the original tests gave the correct results. Perhaps the biggest change has been the realisation that huge 'distortions' of the music signal can be slipped past most listeners if done correctly, so we now have perceptual coding. In addition, it has always been clear that many listeners don't like high fidelity sound reproduction, but prefer something different.
Surely this was done (at least by the Germans) in the 1970s? DIN standards for hi-fi? These days, of course, people prefer personal freedom and market forces so would not wish a standards committee to tell them what to buy. Standards now stick to boring things like safety, interoperability, EMC.IF IT WAS a "done deal" then surely there would be a "standards committee" set up that would have proposed a set of "standards"? You know, that say that it's sound is undetectable, or whatever you want to call it... passes DBTs & ABXs with a statistical probability of <fill in the blank>.
In which case, all the mfrs would be trumpeting "our new ultra blowhard unit meets and exceeds the blankety-blank standard"!!
It is a modified version of "if you have never played with X then you have no right to apply circuit theory to X". Or "my system cost a lot more than yours, so therefore I have better hearing than you". Or "I have sold a lot of items or written lots of articles, therefore I know more than you". Or "I have been playing with electronic experiments for many years, therefore I understand circuit theory better than someone who has read a textbook - by the way, that Fourier fellow talks a lot of nonsense, doesn't he?".billshurv said:PMSL. You have been on the forum longer than me so you know more? Is that how it works? Chortle.
Lowest THD does not necessarily correspond to lowest audible distortion - but I assume you know that? Increasing THD as the bias is changed is likely to vary the distortion spectrum, which may be audible or may not be audible depending on how much distortion there is and what the spectrum is. Why are you asking these questions: seeking knowledge or seeking an argument?bear said:So, let's consider another hypothetical case...
...given amplifier model "Boondoggle", we find that this particular amp has the lowest distortion at a particular bias point (found of course by measurement of THD vs. bias).
Now, let's say that the distortion figure works out to be say 0.003%. If we raise the bias higher the distortion can only increase, not decrease since we have found the lowest distortion bias point. Similarly, if the bias is decreased the distortion will also go up, not down. There will be two symmetric points on either side of the distortion minimum where the bias will be higher and equal when measured.
Will those two bias points when listened to sound the same??
or
Not sound the same??
Same THD; sound different? Of course, unless that THD is sufficiently low. Same distortion spectrum, same frequency response, same clipping behaviour, same output impedance, same noise/hum level; sound different? Probably not.The underlying question is essentially, boiled down, is it possible for two amps (in this case according to Kindhornman's post) to sound different while measuring the same THD.
So you can only hear differences when, by some means (such as level differences), you can be sure which device you are listening to? In other words, you only hear differences when you expect to hear differences. When you can't tell whether you should hear a difference you don't hear a difference. To me that sounds rather like "they sound the same, I can't tell them apart, except by some means other than what they sound like (such as how loud they are, or what they look like, or how much they cost)".john curl said:Second, I tend to lose track when listening to level matched electronics when both preamps (for example) are operating class A and the music is constantly changing in timbre. I can hear differences when I can keep track of which preamp I am listening to, but I lose track when an unknown (x) is presented for a short time as to which it is.
"Better" can be confused with 'prefer', but even then it is useful to know whether someone can actually tell the difference between what he professes to prefer and what he does not. If I say I prefer chocolate icecream to vanilla icecream it might be useful to check whether I can tell the difference when I can't see the icecream; otherwise the truth might be that I prefer brown icecream to yellow icecream.Jakob2 said:And any experimenter should ask himself if the ABX is really needed as it tests for a result that is in reality not so much interesting. (people quite often are looking for something better not just for something different)
Originally Posted by john curl
Second, I tend to lose track when listening to level matched electronics when both preamps (for example) are operating class A and the music is constantly changing in timbre. I can hear differences when I can keep track of which preamp I am listening to, but I lose track when an unknown (x) is presented for a short time as to which it is..
And that John is an honest account of what we are trying to tell. The preamps sound so much alike that your ears only cannot determine any differences so your brain is at a loss, and consequently you are confused.
Your brain can tell you which is playing at any one time when your eyes can see it, or a buddy tells it, or whatever additional non-auditory clues are present.
Jan
Its ok to not be able to tell similar spec'd amps or pre-amps apart. It is not a crime.
People buy equipment because it
1. They see an advert, a picture or a friend tells them about this awesome gear they saw. We could call this 'nascent product lust' or NPL for short.
2. They go and find the product. It sounds good - I'm sure a JC designed 400W Parasound amp is awesome paired with some B&W 802's
3. They like the way it looks. Polished aluminium, chrome, high quality printing, weight and feel - no different to an auto! It looks like an 'engineered' product.
4. As they hand over their money, the 'pride of ownership' thing kicks in: "**** it man, I actually have one of these things" is what they are thinking. Then there's the excitement that follows.
5. For the next two weeks, they get up early every morning, go down into the living room to look at it, stroke the dials, feel the heft, enjoy the quality of the thing, congratulate themselves on their purchase.
So, when you design a piece of audio gear, or a car, a chopper motorbike or anything that is going to sell for a few thousand $, this 1-5 above is what you are aiming to do for the customer.
ABX and DBT tests are a small part of it.
Between the real electronics experts here isn't there a way to create an AB or ABX control system that is noiseless, so no clues to which selection is chosen? Do you have to use a mechanical relay to do this, or is there a noise free, at the level of audibility, mechanical relay that exists?
I can see how an AB test would be easier to identify a difference than an ABX test but do understand how a random factor(X) reduces the probability of a simple 50% guess in determinations.
What would the minimum number of test subjects be to have a statistically significant and reliable bell curve that would show a trend or number of outliers, (true Golden Ears) in the general population? Statistics was not my best subject!
People buy equipment because it..1-5
Feeling pleased with your Nespresso pod popper, Mr. Russell ?
Not the only possibility, different residual DC offsets at input/output can cause a pop when flipped around..
Indeed, if two items sound the same to you, that's just that. Not terribly important in the grand scheme of things.
And using ABX/DBT for a purchase decision isn't terribly useful either.
Blind testing is an important tool during development when you want to find out what the effect is of circuit changes, part substitution, matching, that sort of thing.
Edit: Andrew, see my sig line ��
Jan
Jan, Richard Heyser was referring to someone like me. Yes, I am an audio magician. I can make standard audio product designs stand out and be subjectively better than others. That's my job! '-)
Most magic IS trickery, but audio 'magic' is often unexplained, rather than deliberately added to trick somebody, it just works!
Fade up and fade down a masking noise before and after each switching operation. This was to be part of the switcher I was working on for Harman, and I believe they do use something comparable now with the speaker mover. Note that this is a completely independent sound source, not something supplied by the devices under test.Between the real electronics experts here isn't there a way to create an AB or ABX control system that is noiseless, so no clues to which selection is chosen? Do you have to use a mechanical relay to do this, or is there a noise free, at the level of audibility, mechanical relay that exists?
Thanks Brad, that seems reasonable. At the same time does the added sound cause any mental confusion when making a comparison?
Scott,
The dc you are talking about is from the devices under test or from the mechanical relays?
Scott,
Yes, you create a credible illusion!
Scott,
I was thinking the DUT's, this would not always be a problem depending what you are switching in and out just something to watch for.
Scott,
Former: probably a good thing, unless you're saying it negatively affects the short-term memory of the prior test.
Latter: asymmetric DC offset in the DUTs, most likely, but may creep in from the switching hardware itself. Probably benign unless the DUT is seriously messed up, but I haven't spent much time listening to relay clicks under different DC biases. 🙂
ABX =/= DBT except as a rhetorical trick. It is one possible format for proper ears-only testing, albeit a very useful one. I suggest several others in my LA article.
Of those you propose, which would be best IYO and would it be low cost? If not low enough cost we will never get enough people doing such tests to get a consensus on the matter.
-RNM
Beats me. Remember that the devices under test [edit: that is, for the Harman system] are loudspeakers, and the masking noise is to mask the speaker mover's noises. Also each speaker has an independent power amplifier---there is no switching except for line-level inputs. In my original design I used photoconductors to smoothly transition between line level signals with preset gains, which would be completely bypassed at the end of the switching operation by mercury-wetted reed relays. But this system was never completed---it was going to require more money and that had to come from somewhere, possibly a secretary being let go, which was unpalatable. There was also the concern that at the end of it all the monster wouldn't work. In their defense I really didn't jump on the project as quickly as I should have, instead starting to design new products for the consumer group. The two principal people interested in the switcher were not equipped to evaluate my designs on paper, which didn't help.Thanks Brad, that seems reasonable. At the same time does the added sound cause any mental confusion when making a comparison?
In the case of electronic components the slow transition between selections via the photoconductors would probably allow for the absence of the masking noises. As far as I know there is little motivation for testing source components, preamps, and amplifiers per se, although Olive occasionally remarks that he will have to do something someday, despite the strongly-held belief that results will be null ones.
- Member Areas
- The Lounge
