Need help with noise troubleshooting
I made a copy of Marshall jcm800 , with a little modify at output stage (use 12ax7 as power tube).
My problems are ;
1. it very noisy .the noise goes up as i turn up the master volume and gain , even in clean channel.
2. All my fuses are blown .The power transformer rating is : input 100v ,ouput 200v 80ma and 6.3v 2A.Output transformer is 5w primary 10k ohms, secondary 8ohms.Pre amp tube are 12ax7 x3 , 12au7 x1. I used 250v 100mA fuse for F2 and 125v 300mA fuse for F1.Every i connect the amp to AC the fuses are blown , but if i use cooper wire instead it works but very noisy .
Can anyone help me with troubleshooting please !
Thanks in advance , and sorry for my bad English !
This is my schematic
