AX tech editor
Joined 2002
So, in light of the need to be able to compare LP to digital sources in a fair way, I am in the testing phase now, and hope to be able to introduce in early spring 2017 the Surface Noise Emulator Ultra.
After significant testing and measurement it has been decided that the average level of the SNEU unit is -63.8dB. You will be able to both play this back via separate speakers (if you have the gear on hand), mix with the signal source AND importantly import the algorithm onto your computer and embed in copies of your digital files.
Now, for the first time you will be able to effectively compare LP and Digital on equal footing.
Interestingly enough blind testers have reported that when using the SNEU digital sources sound more "liquid" and "natural".
White papers coming from the research department soon.
_-_-bear
Good idea! You can show these people up!
https://www.izotope.com/en/products/create-and-design/vinyl.html
https://www.audiothing.net/effects/vinyl-strip/
Jan
If that's important to you, it's easy to make a cable. Me, I build stuff for my own use so I don't have to deal with QWERTY compromises.
Sorry sailor don't quite catch the cut of your jib?
Qwerty?
What sort of wire configuration should best be used?
Are we using these single ended or balanced only?
Ok so three simple questions:
Subjectively in your system:
- does the technically "best wire configuration/type" (as measured & according to theory) also sound best?
- does the technically "not as good wire configuration/type(s)" sound the same or not as good?
- does it matter to YOU if the wire you choose to use is randomly acquired wire, or do you want a specific wire, specific material and composition?
What have you found?
_-_-
QUERTY: epitome of largely arbitrary standardization. Ergo, when you DIY you can go bespoke and choose whatever works best for your system.
I.e. one of the biggest advantages of DIY is that you can design from the source through the speakers and make decisions that have the overall goal in sight. Rather than mix and match and try for some sort of serendipity.
New phono stage? decided what you are going with?
A fun project in minimalism, one stage differential folded cascode all FET open-loop, using a very simple common mode feedback. Impedances are high so all caps are NOS TRW PS. I know heresy, no 8-legs. I already tried just a mic pre-amp and the mini DSP RIAA that worked fine for me.
Disabled Account
Joined 2012
Richard, go back to the link and look at the density of flux lines.
For DC, within the wire, the flux is zero at the center of the wire, rises linearly to a maximum at the surface of the wire, and external to the wire, it has a 1/r relationship.
John
This is the diagram I am referring to.... comment pls.
View attachment flux field within wire.pdf
THx-RNMarsh
THx-RNMarsh
THx-RNMarsh
THx-RNMarsh
That is a 2-d sectional view of the magnetic flux lines generated by a solenoidal coil. I suspect you've mixed pages.
https://www.google.com/search?q=sol...OAhUKPz4KHZ-SBW8QsAQIGw#imgrc=x7KNZUsBmtaaAM:
Edit: that is also what the sectional view of the magnetic field of a stripline looks like. Here is a link showing a strip 6 mils over a wide ground plane. If you fold the depiction at the upper surface of the groundplane (at zero) mirroring the fields, you will show the mag field lines with two equal width strips but spaced at 12 mils apart. Note that the currents in each strip are opposing, one into the page and one out of. If you ask marce, I'm sure he can provide more details, as striplines are his bailiwick..
https://www.google.com/search?q=str...OAhWM2R4KHebTCSsQsAQIPQ#imgrc=57FqrXuGg1p0wM:
If you go down a bit on that search, you will also see a differential pair depiction on www.sigcon.com with colors, it shows directly the magfield lines due to a pair of strips.
John
edit: oh, that is funny. I copied the link, and the entire search shows up. I forgot to go to the page first, then copy the link...
Joined 2014
Planning to post/publish one you have it running? The minimalism doesn't suprise me given how much of your working life has been taken up with 8-legs.
diyAudio Member RIP
Joined 2005
a college roommate I recently talked with at a alum event mentioned his daughter's problems with her hair salon business - multiple investigations/threats over the large weekly cash deposits at the drug money laundering regulation thresholds
http://www.bizjournals.com/bizjourn...s-millions-from-law-abiding-businesses-3.html
It's funny how easy it is to detect that some restaurants are laundering money.
I used to go to a very good Italian place near Cal State Northridge when I worked at Harman. One day I pulled into the parking lot just as two expensively-dressed gentlemen were getting into a high-end Mercedes that was rather dusty. The scowls on their faces, muscular builds and general demeanor suggested mobsters, or maybe just prepping for a casting call for The Sopranos. I was fascinated but realized I'd better not stare :)
Kamis, maybe things have not started off not very well, but I might agree with you to some extent. In the history of audio and as measurement technology has evolved, at times people who relied on what they could measure with a given technology later turned out to be wrong about what humans can hear. That being said, measurement technology has improved over time and gotten a lot better. At the same time, it is well known that people can believe they hear things that just aren't there. It's something similar to the placebo effect that is well known in medicine and affects all humans to some extent at times. So, we have limits to what we can measure, and limits to what we can hear, and history has shown that errors have occurred with both. So, wanting to measure, especially given the best measurements we can make today is not a bad idea at all.
I have never heard difference between two different brand of metal film resistors. Or two power supply capacitor. So I not influenced with placebo.
With WBT bass is immediately drier, firmer ,acoustic guitar more focused,more neutral and less thick etc.
In the past , many people used to directly solder cables eliminating connectors, always with clear improvement. Where we must use connectors, WBT emulate directly soldered connectors.British made preamp DN audio had soldering tags instead RCA connectors on MC cartridge input.
Mr John Curl is a designer who reports differences in sound between various soldering alloys, wires, resistors and even PCB material. I suggest him that as a part of development of his high end preamps replace in critical position Vampire brand RCA connectors with WBT Nextgens.They are expensive, but many members here have 1000+ tonearms and DAC-s.
Disabled Account
Joined 2012
and could a single wire be like a single turn coil or similar? The flux lines still looking similar (though weaker) thru the length of the wire and out. resulting in similar higher density in center compared to surface.. as I depicted?
For skin-effect to get established, the center of the wire must (in engineering terms) become a higher Z.... or the HF would go thru the center also and not just on the surface. Does increased flux density in the center make it higher Z?
Comment pls.
THx-RNMarsh
kamis, are you near any broadcasting stations? When I lived nearly underneath a high-powered television broadcasting tower (holding other antennae as well), I found that different connectors and cables strongly influenced the amount of very annoying buzzing that came through the speakers when I used a MC phono cartridge. This was well above placebo-likely levels -- with some cables it was at "turn that damn thing down!" levels. The phono preamp I used was built into an old PAS-3X chassis with tin-plate phono connectors. The mating connectors that gave me the lowest buzzing were actually cheap tin-plate types also (because same metals?) from Radio Shack in the 1960s! The very worst were some gold-plated, quite short, "Gold-ens", some of the first "high-end" IC cables on the market. Soldered connections were pretty good when I tried them, but not very convenient. Of course cable lengths and placement also had strong effects (they were acting as antennas I assume).
and could a single wire be like a single turn coil or similar? . (Not really) The flux lines still looking similar (though weaker) thru the length of the wire and out.(in a straight wire, the lines are straight. Your depiction has the flux lines predicting the end of the wire, that is not the discussion we are having.) resulting in similar higher density in center compared to surface.. as I depicted?
The flux down the center of a wire is zero density. It is a consequence of attempting to take the integral of zero area with no current within.
AS I previously linked to initially, the flux is a linear increasing function from the center of the wire to the surface for DC.
No. The eddy currents cancel out the center current and increase the edge currents, this is depicted on the wiki page also previously discussed.
No. The cancellation of transport current by the eddy currents decreases the current in the center of the wire.
There are two sources of current density profile modulation within a conductor. When it is caused by it's own rate of change of current, we call it skin effect. When it is caused by a rate of change of magnetic field from another source, it is called proximity effect. This can be the return conductor, or it can be magnetic elements such as an iron core as part of the magnetic system.
Proximity effect is what you are actually referring to. This effect causes current centroid modulation towards the path of least impedance. ( This is a huge issue for me with high bandwidth magnets, as the proximity effect can cause a 100 milliohm coil to rise in resistance to tens of ohms at the hundred to thousand hz range.)
You are mixing the two effects together incongruently.
John
Disabled Account
Joined 2012
yes. i am trying to find a simplified engineering model rather than physics model.
So, let me try this for an equivalent engineering model... With flux density highest away from center (with current flowing, of course), and making the Z higher at the outside (skin). So, that increase in Z at HF would effectively leave less conductor area (effectively smaller wire gauge) thus higher Z at HF.
Can you live with that? Rather than the pure physic answer? In electronic apps we dont need exact physic to build something useful using simplified explanations and models. That is what I am looking for which isnt completely accurate nor inaccurate.
THx-RNMarsh
And now for something completely different.
Want to do some case temperature monitoring on some plastic cased transistors (BD139 to be specific). I have some low mass Type K thermocouple probes (the ball at the end is a bit under 1mm).
Can I get a reasonably accurate reading by just touching the ball to the case, or do I need to try and drill into the case and glue it in? The devices are already installed so it would be a bit of a pain to try and drill into them now.
se
