What the Cap!!!!?
The black lead of your meter goes to ground (chassis) and the red lead measures the voltage on those 22 ohms that go to Q901 and Q902. You should see plus 30 and minus 30 volts or more on each.
Lets try this again.
Q901
B -22.44V
C -34.14V
E -21.90V
Q902
B 22.52V
C 33.86V
E 21.96V
Q906
B 16.50V
C 21.96V
E 15.90V
Q905
B -16.42V
C -21.90V
E -15.74V
D902 fluctuates between -.8 to almost -2 but does it rather quickly.
Those all look good apart from the diode.
Make sure you are on the correct end of the diode... if so then just change the diode and the cap. Was that the cap that blew up ? If so then the diode is duff and that will be what zapped the cap.
All the electrolytics have been replaced. I just doubled check and on the striped side its fluctuating around -0.06V and the non striped end its -.8V to almost -2V.
1/ Check that the PLUS 22 volt rail is OK from regulator Q902.
2/ Check that the MINUS 22 volt rail is OK from regulator Q901.
3/ Check that the PLUS 15 volt rail is OK from regulator Q906.
4/ Check that the MINUS 15 volt rail is OK from regulator Q905.
5/ Check the auxiliary negative volt rail that powers the front panel LED and also operates the muting circuit (relay 🙂) is present and correct. You should have around MINUS 30 volts on the anode (that's the non striped end) of D902.
Check all those 5 voltages first.
I almost forgot to ask, where did you find these rail voltages? I would assume being able to do so comes a long way in trouble shooting errors.
The emitters of Q901 and Q902 are the plus and minus series pass regulators, Q905 and Q906 are simple series pass devices that reduce the -/+22 volts down to -/+15 volts by means of the resistive divider on their base/s. The latter are not regulated and stabilised.
