Is there a hardware solution that will take HDMI as input and de-embed the DSD audio stream to either DSD or DoP?
This will be interfaced directly to the DAC chip that is both DSD and DoP capable.
I wasn't aware HDMI used a DSD audiostream. Even if it did DRM would raise its ugly head.
In the Oppo 105D it's an option to choose between PCM and DSD but only on it's HDMI output.
Armand,
Did you ever find a solution for this? If so, what was the solution?
If not, they have de-embedder's that may work? What I would like to know is what happens to DSD when output to coax/analog?
Here's one for example - it's retired now but you can find them used HAE 100 | Extron
