Stochastic versus deterministic is the distinction.
EDIT: reminds me of a big paper I wrote and in the beginning made this distinction---and thereafter never had the need to use it, as everything involving noise was stochastic. Oh well, non-refereed publication.
But it sure helps keep conversation clear and concise, especially since we have so many non-native English speakers (not that they're any worse at English!). Why be lazy about our language? It's not like that's a super low-level term known to a dozen people on the planet. Noise vs other spuria.
95dB at 50/60Hz and greater to over 100KHz. Those numbers from a CFA should put the PSRR debate to rest for CFA. It will work very well IMO.
I hope we get X-talk build as good as well. Your distortion and slew rate and noise are all excellent. But also OPS isolation backward.
I am looking forward to hearing them with the new JBL M2 Master Reference Monitors.
The amp build in progress --
THx-RNMarsh
Wow Richard! Can you share some details of the build? Looks fantastic
Everything with respect to highest quality audio can be both important and demanding. This is where dismissing what 'might' be important, so as to make it easier to do (or lazier) does damage to people's opinions who search for the best.
We can't PROVE everything in audio subjective discernment, but we have found through experience, not just by ourselves, but by others who use our or similar audio designs, that it is almost impossible to 'over-design' a quality audio product. Perhaps, 2" of the wrong connecting wire could make an audible difference. This happened to Roger Skoff, in one case and he pointed it out on facebook, just today.
Derf,
At least we can say that the speaker though having low conversion efficiency and can create distortion it is not the source of noise unless something is wrong with the speaker. I haven't seen any speaker builders equating any magic sound improvement to the tinsel lead-out wires in their speakers, perhaps I have just missed that!
Skoff, the wire huckster?
:spin::spin::spin:
the junctures between the crystals of most copper wire—are not insulators, at all, but semi-conductors; whole gangs of tiny diodes that do affect the passage of signal through the wire (especially stranded wires, where electrons, always seeking the straightest path, will jump from wire-to-wire in a stranded conductor, passing, in the process, through two such tiny diodes with every jump. (Do you remember what two diodes are? The answer is a rectifier, which does exactly the same kind of filtration in a wire as it would do in the power supply section of any piece of electronic equipment.) For the wires in a hi-fi system, the result can be a quite noticeable loss of detail.
Well SY, this is where our opinions differ markedly. I only recently met and talked to Roger Skoff, and I have never tried his wire. However, his opinions, separately derived, parallel mine in the vast majority of cases. Apparently, he and I hear alike, and you and I do not. We (Skoff and I) try to make audio quality better and better, even if we have no commercial stake in what we are looking at. You call us 'hucksters' but you are wrong in this opinion.
Funny when you say it it's OK but when I do I'm wrong.
You see, it’s never OK 😀
And yes I disagree with Georges word usage
Ed and Scott
Buzz is the proper word for what I have experienced with the through the transformer core capacity coupling btn live and chassis.
Ed I am all for using words which have a definite meaning. Makes for a positive communication.
It's also my understanding that hum is almost always a result of magnetic coupling ( if not entirely a result of mechanical coupling from a vibrating transformer). And buzz almost always a ground loop issue
https://www.dropbox.com/s/snli120yfug1aiw/Copy%20of%20hum.wav?dl=0
https://www.dropbox.com/s/mmlutbaavng31bg/Copy%20of%20Buzz.wav?dl=0
George
