Luminaria?
i think this little "transistor" doesn't exist at the article schematics.:rolleyes:
what is the purpose of this transistors?
thanks.
I used the TO-220 version also in my own build and it worked fine, and you need to be aware that the pin-outs are different.
So I think I'm ready to build one.
Thanks for your info.
this different approach seems interesting, replace buffer transistor with tube
Yes that would be interesting.
But I will try the original taste first.
Pass DIY Apprentice
Joined 2001
Here's a little secret: I chose that particular topology on the buffer so I could try a 2SK79 in that spot, but knowing there weren't many available for diy, I made it so the depletion MOSFET would work just by changing resistor values. And that's why the odd choice, and not the garden variety 2SK170 circuit.
Now you know...the rest of the story.
I guess is a solution for a problem that not exist.
My humble opinion frenchie friend....
I have ready lot of gain from CD player ...
yes i can use phono section with SRPP Anzai preamplifier for music on vinyls but that is other story....
With balanced DAC and balanced input vfet amplifier for example CSX1 i can take off jfet buffer and lot mechanical imperfection in disc mouvement and all motor noise from CD player. I say other solution :)
